Old 03-14-2009, 05:36 PM   #1 (permalink)
o2 sensor setting for economy
Hello everybody.
I have a Suzuki Baleno SOHC 16V G13BB 1.3L car. The factory setting for the O2 sensor at exhaust manifold is 0.8v. If i bring it down to 0.45v will it help fuel economy and is it safe for the engine. I don't want to ruin my engine. Or is there a way to do it.
Thanks.
Old 03-15-2009, 03:20 PM   #2 (permalink)
Send a message via MSN to markweatherill
The O2 sensor should fluctuate between 0.2V and 0.8V or something similar, when the engine is warmed up. How are you measuring it?
Old 03-15-2009, 04:24 PM   #3 (permalink)
Driving the TurboWeasel
You can't "set" an O2 sensor for economy. They're an item that fluctuates in output by design.
It could be worn out, and when it reaches a certain voltage the engine finally gets the correct amount of fuel.
I'd get a new one, throw it in, and duplicate the measurement. Bet it's not possible.
2012 Chevrolet Cruze Eco 6MT
Old 03-15-2009, 09:25 PM   #4 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
Hi Aamir, Welcome to ecomodding! See if this or this helps (or doesn't)! Normally ecomodder search is very helpful, and so are the links at the bottom of the page.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 09:35 PM
O2 Sensor Resistor Matt Herring EcoModding Central 11 06-26-2008 04:47 PM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 09:11 AM
WTB: 1 wire o2 SVOboy For Sale 8 05-11-2008 06:01 AM
