Old 05-30-2008, 01:58 AM   #11 (permalink)
Lead-Footed EcoModder
PolyOlefin's Avatar
Torqueless Wonder - '06 Honda Civic Si
90 day: 34.46 mpg (US)
If it was my car, I would get the oil analyzed at 10K if I was going to go that far or more. That's the only "evidence" you're going to find. Otherwise, you wouldn't know when the oil was degraded to the point of damaging your engine. While M1 may be able to protect Engine A for 10k, it may only be enough to protect Engine B for 7,500.
Pennzoil Platinum is a cheaper and I think better alternative to M1. A quick search on the BITOG forums will answer any questions.
Boutique oils like Amsoil (which I'm currently using) have specific oils meant for extended drain intervals. The one I'm using advertises 35,000 miles normal service and 17,500 severe service, though I take it with a grain of salt. It's quite expensive, and only worth the money if you decide to follow their schedule (in which case you would save money).
Does your car have the same Toyota 1.8L 1ZZ-FE as newer Vibes and Corollas? Here is a Used Oil Analysis of an '06 Vibe with 7500+ miles on Havoline synthetic. Results look perfectly okay.
------- 100hp/L specific output, naturally aspirated. -------
Old 05-30-2008, 11:42 PM   #12 (permalink)
Blue - '77 Chevy P/U
if its mostly highway go 5k and change the filter and top it off,, full service a 10k
Old 05-31-2008, 12:05 AM   #13 (permalink)
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
I'm using amsoil 0w30 in the saturn. I wouldn't go over 10k without a UOA either. I run 0w20 in cooler weather.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 06-02-2008, 03:58 AM   #14 (permalink)
Curious....
koihoshi's Avatar
DoesNotHaveANickname - '99 Ford Escort ZX2
I usually change mine at around 5k.
But don't ask about oil brands, that's like asking what religion everyone is a part of because everyone is so crazy about who's is the best oil LOL!
Some really cool stuff on oil analysis at this site:
http://www.bobistheoilguy.com/
Old 06-10-2008, 02:11 PM   #15 (permalink)
POS - '97 Ford Aspire
90 day: 47 mpg (US)
royal purple advertizes 12k intervel
Old 06-11-2008, 10:08 PM   #16 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Thumbs down
"Royal Purple advertises 12k interval."
They also would have you believe that Iron Man uses their oil.
--- Bror Jace
Synthetic Transmission Fluid Change RH77 EcoModding Central 12 11-14-2010 09:34 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Is aero. vs. MPG change linear ? Cd Aerodynamics 9 04-09-2008 11:07 PM
Low viscosity and/or synthetic gear oil? Dane-ger EcoModding Central 7 01-13-2008 07:58 AM
Article: CAFE Change Looks Likely SVOboy General Efficiency Discussion 0 12-05-2007 12:24 PM
