EcoModder.com
-   -   Synthetic oil (https://ecomodder.com/forum/showthread.php/synthetic-oil-21878.html)
fischermatt 05-11-2012 06:38 PM
Synthetic oil
Has anyone heard anything about synthetic oil dramaticly increasing MPG?
I want to try in but want to hear what you all have to say first.
smokey442 05-11-2012 07:43 PM
I've seen some big numbers on dyno tests in the enthusists magazines. Personally going from mineral based to synthetic of same viscosity showed little improvement. Going from 10w-30 synthetic to 5w-20 synthetic was too small to measure accuratly. At operating temp oil pressure took a huge dip.
redpoint5 05-11-2012 09:35 PM
If synthetic dramatically increased MPG, then manufacturers would require this type of oil so they could boost their EPA fuel economy figures.
Vman455 05-11-2012 09:53 PM
Changing to a synthetic oil of the same viscosity won't make a difference. The benefit of using synthetics is a longer life without viscosity breakdown, as synthetics (and the very refined mineral base stocks sold by many manufacturers as synthetics) naturally have a wider viscosity range than typical mineral oil and require fewer friction modifiers, which break down over time.
tortoise 05-11-2012 10:38 PM
So, how about changing from 5W30 mineral to 0W30 synthetic?
mcrews 05-11-2012 10:46 PM
the only thing that will show 'dramatic' increase in mpg is "adjusting the nut behind the wheel"
Ford Man 05-11-2012 11:47 PM
Changing from 10w30 to 0w30 isn't likely to net any noticeable mileage benefit. The only difference in the two weights is the cold start viscosity. One acts as a 10 weight on start up, the other acts as a 0 weight on cold start up and they both act as 30 weight on a fully warm engine. I've never used synthetic, but if mileage gain is all you're looking for in the change from conventional to synthetic it wouldn't be worth the extra cost associated with synthetic. I think the money would be better spent on giving your car a tune up. Personally I've never had any problems with conventional oil in about 1M miles of driving, with one of my cars being at 518,700 miles on the original engine. I run 10w40 in my '88 Escort and have a lifetime average since I started my gas log on this site of just over 41.5 MPG combined. The old highway EPA rating on it is 42 and the old combined rating is 37. Adjusting driving habits will do much more for fuel efficiency than changing to another weight oil.
Brad9660 05-12-2012 12:21 AM
I agree with mcrews, with the exception of modification on the level of the Aero Civic.
mwebb 05-12-2012 01:01 AM
no credible reason to not use "synthectic" oil
there is no credible reason to use any oil except
synthetic oils in your engine .
most "synthetic oil" is not really synthetic oil
you need to read the specifications on the back of the oil bottle
for fuel economy
ACEA A1 B1 - A5 B5
for most engines for maximum life and minimum engine deposits
ACEA A3 B3 - A3 B4
Effects of Shearing - Bob is the Oil Guy
the correct oils will prolong engine life and increase FE slightly and
are "cheaper" to use than
the
DOGSHNIT oils most people think are "good enough"
guudasitgets 05-17-2012 09:06 PM
mwebb look at my fuel log, no diffrence at all
