Old 05-11-2012, 07:38 PM   #1 (permalink)
roller - '08 Toyota Corolla
90 day: 41.49 mpg (US)
big blue - '91 Dodge W250 LE
90 day: 18.33 mpg (US)
Synthetic oil
Has anyone heard anything about synthetic oil dramaticly increasing MPG?
I want to try in but want to hear what you all have to say first.
Old 05-11-2012, 08:43 PM   #2 (permalink)
I've seen some big numbers on dyno tests in the enthusists magazines. Personally going from mineral based to synthetic of same viscosity showed little improvement. Going from 10w-30 synthetic to 5w-20 synthetic was too small to measure accuratly. At operating temp oil pressure took a huge dip.
Old 05-11-2012, 10:35 PM   #3 (permalink)
90 day: 38.47 mpg (US)
If synthetic dramatically increased MPG, then manufacturers would require this type of oil so they could boost their EPA fuel economy figures.
Old 05-11-2012, 10:53 PM   #4 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Changing to a synthetic oil of the same viscosity won't make a difference. The benefit of using synthetics is a longer life without viscosity breakdown, as synthetics (and the very refined mineral base stocks sold by many manufacturers as synthetics) naturally have a wider viscosity range than typical mineral oil and require fewer friction modifiers, which break down over time.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 05-11-2012, 11:38 PM   #5 (permalink)
tortoise's Avatar
number 9 - '89 Geo Metro LSi
90 day: 49.25 mpg (US)
So, how about changing from 5W30 mineral to 0W30 synthetic?
Old 05-11-2012, 11:46 PM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the only thing that will show 'dramatic' increase in mpg is "adjusting the nut behind the wheel"
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-12-2012, 12:47 AM   #7 (permalink)
Changing from 10w30 to 0w30 isn't likely to net any noticeable mileage benefit. The only difference in the two weights is the cold start viscosity. One acts as a 10 weight on start up, the other acts as a 0 weight on cold start up and they both act as 30 weight on a fully warm engine. I've never used synthetic, but if mileage gain is all you're looking for in the change from conventional to synthetic it wouldn't be worth the extra cost associated with synthetic. I think the money would be better spent on giving your car a tune up. Personally I've never had any problems with conventional oil in about 1M miles of driving, with one of my cars being at 518,700 miles on the original engine. I run 10w40 in my '88 Escort and have a lifetime average since I started my gas log on this site of just over 41.5 MPG combined. The old highway EPA rating on it is 42 and the old combined rating is 37. Adjusting driving habits will do much more for fuel efficiency than changing to another weight oil.
Old 05-12-2012, 01:21 AM   #8 (permalink)
92Integra - '92 Acura Integra LS
90 day: 44.18 mpg (US)
I agree with mcrews, with the exception of modification on the level of the Aero Civic.
Old 05-12-2012, 02:01 AM   #9 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no credible reason to not use "synthectic" oil
there is no credible reason to use any oil except
synthetic oils in your engine .
most "synthetic oil" is not really synthetic oil
you need to read the specifications on the back of the oil bottle
for fuel economy
ACEA A1 B1 - A5 B5
for most engines for maximum life and minimum engine deposits
ACEA A3 B3 - A3 B4
Effects of Shearing - Bob is the Oil Guy
the correct oils will prolong engine life and increase FE slightly and
are "cheaper" to use than
the
DOGSHNIT oils most people think are "good enough"
The Following User Says Thank You to mwebb For This Useful Post:
smokey442 (05-12-2012)
Old 05-17-2012, 10:06 PM   #10 (permalink)
Fokus - '12 Ford Focus SE
90 day: 33.73 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 22.83 mpg (US)
Ezcape - '15 Ford Escape Titanium
90 day: 20.11 mpg (US)
mwebb look at my fuel log, no diffrence at all
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
