Old 10-11-2009, 08:10 PM   #11 (permalink)
...beats walking...
...correct, it's common to wear/chip synchro "teeth" but not the actual mechanically-engaged gear teeth...to break one of them usually means a piece of hard metal (brass might do it, but usually not) has broken loose from something and physically gotten between the engaging gear teeth, which if you notice in the illustrations, are always engaged with their mating gear...all engagement is via the synchro.
Old 10-11-2009, 08:42 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
If someone told me that the teeth broke off the gear, I'd assume they meant the helical splines that engage from gear to gear, which transfer power between gears.
Probably the furthest thing from my mind would be the dog-teeth, or those things that engage the gear to the input/output shaft (whichever one free spins when gears aren't engaged, usually output, I think) so that it can begin transferring power from the input shaft, to the drive gear, which sends power to the driven gear (via the "teeth" or Helix Splines), which sends power to the output shaft, eventually going to the differential and driving the wheels.
The fact that you're getting an easily reproducible grinding noise suggests that you've destroyed a synchronizer, though.
Old 10-11-2009, 08:45 PM   #13 (permalink)
...beats walking...
...my diagnosis too. But, if there REALLY are pieces of "iron teeth" in there, that's BAD news.
Old 10-11-2009, 08:54 PM   #14 (permalink)
Most definitely. In fact, I'd be inclined to say that if there are pieces of anything in there, trouble is afoot.
Old 10-11-2009, 08:58 PM   #15 (permalink)
...beats walking...
...both require tearing down the tranny, but IMHO swapping in new synchros is much easier and less costly than changing out a mating gear-set (because, then you really should refresh all the synchro too...ultimately too much money).
Old 10-12-2009, 08:56 AM   #16 (permalink)
I used Redline in my 03 Matrix (came with it when I purchased the car), and I have Royal Purple in the Paseo. When I put the Royal Purple in the Paseo, it made a noticeable difference when the car was cold in the winter. It wasn't noticeable in the summer. I'd still highly recommend synthetic, whatever brand you go with.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Synthetic Transmission Fluid Change RH77 EcoModding Central 12 11-14-2010 09:34 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Choosing a Manual Transmission Fluid for my Mazda Protege 1337 EcoModding Central 5 03-20-2009 12:07 PM
