05-28-2017, 10:11 PM
#101 (permalink)
T-100 Road Warrior
Got some measurements off of Dark Aero's belly pan to calculate the exit angle.
Length of belly from the end of the diffuser to the end of Dark Aero = 76"
Distance from ground to the bottom of Dark Aero end = 16"
Exit angle from the rear diffuser to the end of Dark Aero = 3.95 degrees.
Overall length = 288".
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
06-03-2017, 12:26 PM
#102 (permalink)
meetup
Thanks again for the meal Bam,and look at the upgrades.Hope you guys got home okay.
06-06-2017, 01:15 AM
#103 (permalink)
T-100 Road Warrior
Rear diffuser lost the bolts on the right front hinge and was flapping a little bit on the way home. I guess it screwed up my numbers a bit.
Got the bolts replaced and bolted the hinge back in. A quick run into Houston in the afternoon was indicating around 25mpg on the Ultragauge.
06-06-2017, 03:16 AM
#104 (permalink)
Did you use Nylock or split washers this time?
06-10-2017, 06:26 PM
#105 (permalink)
T-100 Road Warrior
I had split lock washers on the bolts last time. I've decided to use some thread locker this time.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
06-10-2017, 06:54 PM
#106 (permalink)
07-05-2017, 11:43 AM
#107 (permalink)
T-100 Road Warrior
08-02-2017, 09:42 PM
#108 (permalink)
T-100 Road Warrior
Finally had some time to cover up the crossbeams with the rubber baseboard strips. Zip tied them to the slotted angle about every 8" or so on both angles fer both beams. I'll have to make a run and see if it makes a difference or not.
01-02-2018, 01:52 PM
#109 (permalink)
T-100 Road Warrior
During my 2017 Christmas run up North to Nebraska, I ended up in some serious snow which built up between my main belly pan and the floor boards. The snow didn't even melt when I zipped down to Arkansas fer a few days and I had to remove my side skirts so I could dig it out. Maybe I should configure a winter/summer mode due to the amount of snow that was built up between the belly pan and floor boards with the summer mode sealed up and the winter mode opened up.
I was over rough terrain fer the few days and ended up taking some damage to my rear Coroplast vertical skirt bottom gap covers. I noticed that lower part of right side vertical panel had broken free at the rear and was dragging on the road. I was wondering if having both of the rear vertical skirts dragging on the ground would make any significant difference in sealing off the turbulant air coming off of the rear tires and setting the rear diffuser with cleaner air. The new rear skirts would pivot near the rear axle and contact the road at the rear with a possible option to retract them up when backing up or only using them fer highway use. This would make them a replaceable wear item.
01-02-2018, 04:32 PM
#110 (permalink)
An L shape 1 vortex diameter above the ground is what LeMans cars are doing for their diffusers the vortex (with proper engendering) will act as a solid .
https://www.youtube.com/user/Kyleengineers has a video explaining what I'm trying to say I was not able to find it quickly this morning work to do so I don't have time to dig at the moment
Dream big chisel down to reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
