View Poll Results: Which is better
A - |/ 6 85.71%
B - \/ 1 14.29%
Voters: 7. You may not vote on this poll
Old 09-29-2009, 08:46 PM   #1 (permalink)
I have seen lots of pics of different kinds so I wanted do do a poll on them.
A
Tire
|/ ---outside
Front of Car
B
Tire
\/ ---outside
Front of Car
Which of the two shapes better to have in front of the tire? I was thinking A because it doesn't create higher pressure between the wheels.
I was further unsure if I should ramp it down or just have it be a wedge.
Than my last thought was behind it make a 'boat tail', /\, behind it angled up to return the air to the body.
Last edited by snydertalon; 09-29-2009 at 09:37 PM.. Reason: Fixing crappy ASCHII characters for lack of image hosting site
Old 09-29-2009, 09:28 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'm having a little trouble deciphering the ASCII characters. Perhaps you could indulge us with a picture or sketch?
Old 09-29-2009, 09:42 PM   #3 (permalink)
hope this helps to make sense.
Name:	wheel defuser.JPG
Old 09-30-2009, 02:09 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If I understand your pictures correctly, it appears as if you have two styles of diffuser/spoiler thingees. Seen from above, one splits closer to the center of the car, while the other splits at the centerpoint of the tire.
Did I get that right ?
If so, my guess would be that drag reduction would depend on the suspension pieces around the tire. 'B' would tend to send more air to the sides of the car, while 'A' would split it equally .
If the underside of the car is smooth and the suspension pieces don't hang down much, it still might be beneficial to send the air around the sides of the car.
I'll let the experts answer. What do you say guys ?
Old 09-30-2009, 02:47 PM   #5 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Try using tell-tales to detect the current air flow around the tires, and put the center of the fairings paralell to that.
Old 09-30-2009, 03:11 PM   #6 (permalink)
Here is a really good 2 part series on this from autospeed.com:
Modifying Under-Car Airflow Part 1
Modifying Under-Car Airflow Part 2
The Following User Says Thank You to moorecomp For This Useful Post:
Bicycle Bob (09-30-2009)
Old 09-30-2009, 03:29 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
snydertalon -
I voted "A", but that was a gut-intuition thing.
CarloSW2
American Solar Energy Society
Old 09-30-2009, 04:34 PM   #8 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
my hillbilly know how says A.
splitting into undercarriage where there is an engine exploding under control needs some room before anything gets to it. in front of the tires is a good place to start a wake, and not pretend the engine isn't exploding under control, explosively expanding all the time, explosively powerfully unknowable...bomb like explosively explosive.
Old 09-30-2009, 05:07 PM   #9 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
just some thoughts:
keep in mind that directing air to the inside will direct it inside the inner wheelwell. a good deal of dans seem to be aimed at keeping air out of the well so with that in mind directing everything outside could be a good option.
also note that the part of the wheel that touches the ground isn't moving relative to the ground or the air
(the car is moving trough the air the air just it's there)!
so it could be beneficial to direct some air the the lower tire surface, as the forward speed of the tire surface will decrease relative to the axle.
it's quite logic but it can be confusing,
think of a tanktrack for example, where the tanktrack is layed out in front of the tank on the ground.
the tank moves over it, and than picks up the track, transports it at twise the speed of the tank back to the front and so on. a tank track is basically a very flat tire. so the frontal motion relative to the air decreases. the air is pushed asside though, but rather by rolling over it than by pushing it asside....
this means that rather than directing all the air left and right, directing some down could be a good idea wich would explain why a lot of wheel dams are flat rather than wedge shaped.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 18 04-06-2014 12:14 PM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
