Old 09-15-2010, 07:34 AM   #11 (permalink)
You need to step back and think about the whole car.
The attitude/angle of air flow of the whole chassis matters most, and you cannot change the attitude of the whole chassis and see an over all benefit from just the windshield.
Old 09-15-2010, 11:20 AM   #12 (permalink)
The whole notion is false. Somewhere here is a link to an aero article Hot Rod mag did, complete with wind tunnel experiments. They said windshield angle is not critical.
Cd (09-17-2010)
Old 09-15-2010, 03:10 PM   #13 (permalink)
aerobrick - '04 Dodge Dakota Quad Cab SXT
Frank,
I'm no expert and I agree with you about angle not being "critical" but I do have a question about the windshield transition. We are really talking about many small changes that add together to reduce overall Cd so while not "critical" a little here and little there still helps. Would it just be better to put a fairing in front of that transition angle to start air upward a little sooner?
There is usually a set of wipers there and many recommend removal (I won't do that) or a fairing. If you put a fairing in front of the blades would it be "better" to angle the fairing from the hood at angle halfway between the existing transition angle or from under the hood at a sharper angle.
Cycleguy,
As for changing the angle of the entire vehicle, I would say that we ALL need to see the vehicle before we can decide. ie: my truck sits higher in the back by 4 inches than the front and the overall underside of the body is already 3degrees higher in back. Dropping the back (changing entire angle) may make sense for my truck BUT after I put full belly pan on bottom, it might NOT make sense. I will have to see what the rear angle underneath looks like when done.
I would say no to the bigger wheels in front as you would likely get much better results from other things first and likely also to make overall combined Cd worse if you already did some mods and then put bigger tires on.
Don
Old 09-15-2010, 08:44 PM   #14 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
One possible advantage is that it will increase your effective gear ratio and might put your engine into a more efficient point on the BSFC curve.
Old 09-16-2010, 03:13 PM   #15 (permalink)
Originally Posted by dmac257 View Post
Frank,
Cycleguy,
Don
You are correct in saying it is the windshield TRANSITION that is more critical but you are focused on the wrong transition- it is the one from the top of the windshield to the roof that has more influence on good flow and drag than the one at the base of the windshield to the hood. Too bad as that bottom one is the easy one to play with. Do whatever you want there; I'm quite sure you won't see any measureable results.
It is generally accepted that a slight nose-down rake is the most aero efficient.
Big front tires on this RWD won't change "gearing"!
Old 09-17-2010, 11:12 AM   #16 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I assume that cycleguy would be referring to his 94 Metro that he has listed. If this is the case, bigger tires may help a bit with making the gear ratio a touch better. Thing about the metro is, he won't be able to get much bigger than stock without some serious mods, so it would make little difference. My suspicion is the change in gearing ratio will make a bigger difference. However, I have noticed many cars, especially the fuel efficient ones, tend to lean a bit forward. Is this possibly by design?
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 09-20-2010, 03:12 PM   #17 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
In huchos book he said after 60 degrees the gains are minimal.
Tips needed for eco-driving my diesel truck! nubbzcummins Hypermiling / EcoDriver's Ed 65 12-07-2010 01:37 PM
Aerodynamic lift- A real problem Hermie Aerodynamics 175 12-05-2010 07:56 PM
The Daq Civic aero project continues . . . slowly daqcivic Aerodynamics 34 02-09-2010 11:03 AM
