Old 06-25-2012, 09:48 AM   #21 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by JethroBodine View Post
Oooooo. Bar has gotten higher. What do you think you could do simulating their conditions Dave? Got three or four days of vacation time to burn?
If I did, I'd spend it building my belly pan and aero cap
I've actually considered making the 1,627 mi tank my new stretch goal. Originally >40 mpg was my stretch goal. 1,627 would require 46.5 mpg (35 gal). That's a 13.3% improvement over the 1,435 mi tank.
I think it's possible for a couple reasons.
*First, my overhead average for this last tank was better during the second half than the first half (42.6 for the 1st half. 45.3 for the 2nd half). So, if I could do second half mileage for a whole tank, that would be a 3.1% improvement over the whole tank.
*I still have to switch my tranny fluid over to synthetic, and add a tranny pad heater. Together, I think ~2-3% improvement is reasonable for that.
*Third, I suspect a belly pan and aerocap should be able to buy me ~4-5% improvement each.
So all thogether, I think 13% improvement from where I am is possible. Now I just have to do it
P.S. I'm also loosing some miles on the odometer by using the ignition as my kill switch. If I get a kill switch in place I think I should also be able to gain 3-5%
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
JethroBodine (06-25-2012)
Old 06-26-2012, 01:44 PM   #22 (permalink)
This is the year
Bug - '06 Volkswagen Beetle TDI PKG1
90 day: 37.04 mpg (US)
F-350 - '11 Ford F-350 Lariat
90 day: 16.23 mpg (US)
Wow that's amazing. You need to make a training video so I can watch and study it. Congrats.
Old 07-10-2012, 07:53 AM   #23 (permalink)
Update: I slightly bested myself with a 1,457.3 mile tank (41.64 mpg). This tank had some actual work in it (hauling around mulch and landscaping stuff) and quite a bit more non-commuting miles than normal (which typically hurts me), but I think the warmer temps offset that--we had a string of high 90 degree days and then a string of 100+ deg days.
Diesel Dave
Old 07-10-2012, 04:58 PM   #24 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
More miles is more miles, no mater how you slice it.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
