Tapping into signal wires
What is the best (ie safest) way to tap into a signal wire? There are a few sensors that I'd like to monitor, the "signal" is usually just the voltage (eg 0V=open, 5V=closed, etc). Since taking the plug or socket apart is too hard (if at all possible), I have to somehow get into the wires. I can see three options:
If its temporary, I'd do #3. Put some electrical tape over it after you're done just to be safe.
I'm not sure if they are available in Poland, but here the auto parts stores carry splice taps.
they clamp on to the wire and provide a 3rd port for a new wire. when removed the insulation only has a small nick like your needle idea. example: BWD CT617A - Terminal | O'Reilly Auto Parts |
solder a lead to the pin, then stick it into the wire. Wipe a little silicone sealant over the hole(s) when you take the pin out if so inclined to restrict further oxidation.
If you can get at the ends of your wire harnesses (e.g. where they enter the ECU), you can get a narrow probe in there without piercing the insulation.
Apparently what you are seeking is a way to read the voltage of the wires by piercing but not cutting the insulation. It's called pick probing. You will need a few, very sharp dental instruments that can pierce through the insulation of the wire just enough to make contact with the wire. The handle end of the instrument will be attached by an alligator clip to the meter you are using. When you remove your pick, the pin prick in the insulation will be so slight as to need no remediation to the wire or its insulation
(I've only been using this technique for 40 years. If you find it useful a 'thank you' would be appreciated.) ;) |
you could get another connector, and solder pins on the end to fit into the original connector, splicing off a wire as in #1. then when you're done, just unplug your "piggyback" setup, and plug the original connector back in. sort of a man-in-the-middle type setup, and no worries about corrosion/broken wires with method #3. just a thought.
+1 for method #3, the 'pin-thru-insulation.'
...and a single wrapping of self-vulcanizing tape seals everthing up tight. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
