Old 07-07-2013, 03:49 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
100 hp 1 Mile with good aero 199.7 km/h
You dont need 200+ hp to go fast on a one mile drag race. All it takes is lightweight car in this case my Lupo 2l which weight was with driver 880 kg. Car had max 100 hp. Most importantly the Cd value is low it should be in the range of 0.20.
The result was that I was able to reach 199.7 km/h with standstill start. Later will come list which cars were slower.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 3 Users Say Thank You to Vekke For This Useful Post:
euromodder (07-07-2013), Jyden (07-08-2013), user removed (07-08-2013)
Old 07-07-2013, 12:41 PM   #2 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Nice run, Man! Fast, fun AND frugal... Can't beat that!
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 07-07-2013, 02:49 PM   #3 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Nice work!!!
Old 07-07-2013, 05:05 PM   #4 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Looks like fun, but as you probably ascertained, the gearing seems way to low for that task. It looks like you barely made it into 4th by the end of the run and had a very slow start. I would think you should want to gear it so you are winding out in 6th(or 5th if a 5 speed) and have much more torque off the line and probably across the board. Still nice work, probably just pointing out the obvious
The wind noise was a little puzzling too.
Old 07-07-2013, 05:37 PM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'd say you have to work on your launch technique ...
... but you might well have been saving the gearbox / clutch
Old 07-07-2013, 08:48 PM   #6 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
I think 100 horsepower is optimistic the way that thing took off.
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 07-07-2013, 09:06 PM   #7 (permalink)
Way to go!
I've always liked the standing mile as a better test of total car performance than the American affinity for the 1/4 mile. A blend of power and aerodynamic prowess gives you the best results. Your Lupo did well.
Old 07-07-2013, 09:21 PM   #8 (permalink)
also races Sportbikes!!!
SpeedyCorky's Avatar
Mo' Mon-nay! - '00 Honda Civic HX
90 day: 52.26 mpg (US)
Carbon Silver - '06 Honda Insight
90 day: 82.2 mpg (US)
very cool! good job!
yeah u could pull way better numbers with superior gearing and a more agressive start. that car looks really sweet with all the aero u did to it!
2000 Honda Civic HX with mild aero mods
2006 Honda Insight
MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
Old 07-07-2013, 10:24 PM   #9 (permalink)
Am I the only one thinking of nitrous? :P
Old 07-08-2013, 03:26 AM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Official results are in and measured speed was only 199.7 km/h :/. I wish I knew that yesterday so I would have driven second run.
http://www.speedconcept.fi/images/ti...3_tulokset.pdf
I took off in second gear and it was not the perfect start. I have been told that it does not matter much to the top speed on a mile how you lauch off from the line. First gear is so short that in testing second gear have worked better as there turbo is not able to get boost properly up on first gear.
100 hp is max estimation on current injectors. Propably closer to 95.
1 mile, drag race, good aero, standing mile
