Old 09-11-2017, 07:18 PM   #1 (permalink)
PSmodder lurker
Mitsubishi-Fuso wants in e-trucking
Mitsubishi Fuso Truck announced the start of production of its all‑electric truck, the Fuso eCanter. The eCanter has an electric motor; 115 kW with a maximum torque of 390 Nm and six battery packs and a total capacity of 82,8 kWh. Class 4 series; 15,995 lb. GVWR and a 9,380 lb payload capacity. It has a of 100 miles, a one-hour quick-charging capability, and an eight-hour overnight full-charging. The truck has flexible battery configurations, users can choose between shorter ranges for larger payloads or full capacity of 100 miles in limited payloads. Mitsubishi-Fuso wants to become the first global manufacturer to produce all-electric trucks in series production.
https://www.ecanter.com/en
The Following User Says Thank You to botsapper For This Useful Post:
Xist (09-11-2017)
Old 09-11-2017, 07:22 PM   #2 (permalink)
A range of 100 miles?
Old 09-11-2017, 07:32 PM   #3 (permalink)
PSmodder lurker
The eCanter is designed for densely populated areas such as Tokyo, Manhattan or London, where there is a constant need for refrigerated food delivery and urban cargo hauling, as explained by product planners for Fuso. Their first-gen truck will have a limited range of 100 miles per charge, so they are availble for lease-only plan for two years. They expect to rapidly replace this first model with newer versions with greater ranges and semi-autonomous technologies.
