Old 04-06-2011, 04:21 PM   #1 (permalink)
Aeroge - '01 Mazda Protege MP3
90 day: 28.62 mpg (US)
Arrow Window Blind's Grill Block
So there are now a few cars with active shutters for a grill block and was wondering if anyone had thought of doing the same but with a heavy duty window blind set up. Steel may bend so I was thinking about doing plastic. Living in Pittsburgh, (highs 95 degrees to 0) I was thinking this may be a viable project where the cooling capacity could be adjusted...highway closed blinds vs. open in traffic. Manual cockpit controlled. Just wanted to see if anyone had done this or heard of it. Thanks in advance.
Old 04-06-2011, 09:10 PM   #2 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Aerocivic has one.
He took 2 pieces of PVC tube.
one fits over the other.
then cut a slit half way through.
a cable rotates one in the other to open or close the front.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
The Following 2 Users Say Thank You to metroschultz For This Useful Post:
01 Protege MP3 PGHYinzer (04-08-2011), cfg83 (04-06-2011)
Old 04-06-2011, 11:35 PM   #3 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Here's a link to how the one on Chevy Cruze will work.
In Focus - Chevrolet Cruze's (active) Shutter Grille | Auto Tech Blog
The Following User Says Thank You to SoobieOut For This Useful Post:
Old 04-07-2011, 12:53 PM   #4 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
You could always use adjustable floor vents I'd think as well: LIKE THESE
They're just about the right size already and one would only need to run a manual cable or setup a solenoid to activate them.
The Following 2 Users Say Thank You to TomO For This Useful Post:
01 Protege MP3 PGHYinzer (04-08-2011), cfg83 (04-15-2011)
Old 04-08-2011, 09:27 AM   #5 (permalink)
And now the inevitable DIY goal of making it not look like a 1rst grader's art project.
Old 04-15-2011, 06:30 PM   #6 (permalink)
In the 1970s, semi-trucks had shutters in Alberta Canada.
My father once brought home a approx 18"x18" scaled down model of the shutters being sold for large trucks. All aluminum, and very heavy duty. They were sold for the fronts of semis to provide better heat control and thus improved engine efficiency.
I'm back - I found them
BorgWarner makes truck shutters (look just like they did 30-40 yrs ago!)
http://www.ets.borgwarner.com/pages-...-shutters.html
Better pictures here...
http://www.ets.borgwarner.com/PDFs/Shutters.pdf
Maybe it will give you some ideas!
