EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   testing aero. of a caravan (https://ecomodder.com/forum/showthread.php/testing-aero-caravan-32792.html)
aerohead 09-19-2015 02:43 PM
Ran across these on You-Tube:
https://www.youtube.com/watch?v=karGqjCZOV8
chefdave 09-19-2015 04:51 PM
Thats a very dirty wake. Must be room for huge improvement
aerohead 09-19-2015 04:55 PM
huge
NASA says kill the gap,then boat tail it.
chefdave 09-19-2015 05:11 PM
Would a kammback help if boat tail is too long
Hersbird 09-19-2015 08:30 PM
What about that "part 2" video with the topper? Is that better or worse?
https://youtu.be/sweZltfD-no
freebeard 09-19-2015 09:44 PM
I'd go with different. They missed a bet not putting the two videos one above the other and matched in speed.
It's interesting to watch the lines approach from the left. There's some initial noise that damps down to straight lines, but they aren't erased so it obscures the initial approach. There appears to be turbulence building up ahead of the rooftop container, it might be caused by the airgap between the topper and roof.
The topper seems to create a locked in rolling vortex ahead of the trailer, similar to a half-tonneau cover on a pickup.
What do you think about the area above and behind the trailer? With the container the disturbed air rises higher, even out of the rendered flow lines, but it looked somehow more orderly to me.
aerohead 09-21-2015 03:25 PM
kammback
Technically speaking,a K-form tail (Kamm-back) is just a shortened ideal tail (boat-tail),or vice versa.
Here you can see how Koenig-Kamm experimented with different lengths of this K-form at the FKFS,next door to Daimler-Benz in Stuttgart.
http://i1271.photobucket.com/albums/...titled5_17.jpg
aerohead 09-21-2015 03:43 PM
topper
My gut feeling is that this is a low-cost,2-dimentional CFD program,that they don't achieve a critical Reynolds number flow,and while interesting to watch,and trends may be reflected,we'd want an expensive,corporate-level,3-D program to provide a more real-world representation of how things would be.
I don't think the streamline filaments would behave the way they're depicted.
aerohead 09-21-2015 04:02 PM
above and behind
I'm not really convinced that we're seeing flow as it would actually occur.
Here are some comparison images
http://i1271.photobucket.com/albums/...titled10_9.jpg
http://i1271.photobucket.com/albums/...ntitled8_9.jpg
http://i1271.photobucket.com/albums/...head2/2239.jpg
http://i1271.photobucket.com/albums/...head2/2234.jpg
http://i1271.photobucket.com/albums/...head2/2226.jpg
http://i1271.photobucket.com/albums/...ohead2/227.jpg
http://i1271.photobucket.com/albums/...d2/06-2835.jpg
http://i1271.photobucket.com/albums/...Untitled-5.jpg
http://i1271.photobucket.com/albums/...titled8_10.jpg
http://i1271.photobucket.com/albums/...itled10_10.jpg
darcane 09-21-2015 04:26 PM
After watching it, YouTube offered up this gem:
https://www.youtube.com/watch?v=0577mRifVfI
Improved aero over most trailers, but the really interesting thing is the hydraulic lowering by rotating the entire suspension assembly.
