Are there any other Escort modders out there?
I said I had a 98, Mines a 99. Is that a third gen? I have a couple pieces of sheet aluminum that I am cutting for an air dam, and I want to do a belly pan under the trunk and rear bumper.
I am already adding rubber wall cove or whatever you call it. I got it at Renovation Station for $.50 a piece. Each side will require 1 1/2 pieces.
So far so good. If I get it running good and a new timing belt I hope to install CNG in the future
Planned Mods
air dam
grille intake shutters
belly pan trunk and rear bumper
alternator delete, possible alt bracket mod to allow engage disengage ops
install deep cycle battery in trunk for normal operation of car
fan cut off switch
rear wheel skirts
2006 Pontiac Vibe 36 MPG 5 speed
1999 Ford Escort Base Model 2.0 5 speed
Scangage II
WAI
FULL disc wheel covers
Sears Guardsman plus tires 44 PSI
Best tank 42 MPG 244K
