Old 07-05-2009, 12:59 PM   #1 (permalink)
JackMcCornack's Avatar
Is a Metro Xfi cam marked?
How does one identify an Xfi cam? One has come available, but the ownership chain has a "The guy told me it was an Xfi..." link in it. I believe the guy who is selling it to me believes it's an Xfi cam, but maybe he's as gullible as I am and surely there's some way to check.
Old 07-05-2009, 03:11 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
There's a 1mm difference in lift, and the reduced dwell also makes the XFI profile look peakier to the practiced eye.
Old 07-05-2009, 03:38 PM   #3 (permalink)
:-) Lacking a practiced eye, is there a way I can tell? You'd think they'd do something at the factory to keep them from getting mixed up in the field--a number stamped into it, or a peen mark somewhere, or something.
Old 07-05-2009, 04:10 PM   #4 (permalink)
The calipers say that my standard one is 40.4 mm to the top of the lobe. Presumably, the XFI will be under 40 mm, but look it up, eh?
Old 07-05-2009, 06:11 PM   #5 (permalink)
Okay, sorry to trouble you, I was being lazy I guess. I'll go "look it up" somehwere. I'm active on a couple of homebuilt/scratchbuilt car forums and I'm perhaps a bit spoiled, the Locost guys in particular share tech info with abandon, but I'm something of a new kid here on EcoModder and haven't yet learned the customs.
Old 07-05-2009, 07:06 PM   #6 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
There are no markings I am aware of, but if you compare your cam to an XFi or economy cam, you will notice a difference is cam lobe height.
GeoMetroforum.com - got mpg?
Old 07-05-2009, 08:36 PM   #7 (permalink)
The following is from my 1994 metro service manual:
XFI Model
Standard camshaft lobe height is 39.628 to 39.788 mm
(1.5602 to 1.5665 inches).
Wear limit 39.528 (1.5562 inches).
Base and LSI Models
Standard camshaft lobe height is 40.415 to 40.575 mm
(1.5911 to 1.5974 inches).
Wear limit 40.315 mm (1.5872 inches).
Old 07-05-2009, 10:28 PM   #8 (permalink)
Cool! Thanks, OldGuy, that's just what I needed and my Chilton's didn't tell me.
Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed MetroMPG EcoModding Central 31 11-09-2014 05:28 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 12:32 PM
Metro owner mulling over swap to XFi transmission and 1-ring pistons MetroMPG EcoModding Central 10 02-04-2009 01:56 PM
Recently purchased 1994 Geo Metro XFi Z33ky Off-Topic Tech 10 11-15-2008 08:12 AM
