Old 02-05-2023, 12:09 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Orzeszek - '18 Škoda Citigo Ambition
Thermal imaging for engine insulation
I had a chance to borrow a thermal imaging camera to check something at home, and got the idea to check my car's engine bay insulation.
Took 2 pics of the car roughly 10-15min after parking on the driveway. Outside temp was around freezing.
This shows that the majority of the heat is lost around perimeter of the hood. The hood itself has 2 layers of insulation on its underside (the OEM blnaket plus bubble wrap with silver foil on 1 side), so I will need to add a seal around the edge. Any recommendations
Hopefully this will aid with retaining heat when preheating the engine, or after parking while running errands.
ID:	33364   Click image for larger version
The Following 3 Users Say Thank You to Piwoslaw For This Useful Post:
Cd (02-05-2023), freebeard (02-05-2023), woodstock74 (03-24-2023)
Old 02-05-2023, 12:58 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
That's a great idea !
I can also see how this would be useful under the car when creating underbelly coverings.
Old 02-05-2023, 04:18 PM   #3 (permalink)
Why do you think the heat goes up into the A-pillar? Is it just that it's higher than the hood?
