Old 07-31-2014, 07:27 AM   #1 (permalink)
Accord - '95 Honda Accord LX
90 day: 27.43 mpg (US)
2008 Civic IMA Issues
Edit
Old 07-31-2014, 09:33 AM   #2 (permalink)
I'm no expert, but I would probably start with a grid charger if you want to keep this simple. Otherwise you'll have to pull out the pack and evaluate the cells.
Old 07-31-2014, 01:57 PM   #3 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
It seems like it would make more sense to fix it since it has relatively low miles on it, than to sell it. You're gonna get maybe five grand for it, and that will just buy you somebody else's problem car.
As long as the CVT is holding out I'd either get the grid charger or see if anybody in your area works on the battery packs. There's a guy in my area that rebuilds them for like half of the price the dealer quoted you
Wait a minute! Since you're from Kentucky, doesn't it make more sense to fix it by putting a piece of electrical tape over the IMA light?
Old 07-31-2014, 05:22 PM   #4 (permalink)
Depends on the ima codes. Could be a bad BCM, PTC strip or a thermal issue.
Maybe the blower is acting up or the intake is clogged?
Old 07-31-2014, 05:29 PM   #5 (permalink)
Edit
Old 07-31-2014, 05:32 PM   #6 (permalink)
edit
Old 07-31-2014, 07:09 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I would start out by checking or even replacing the 12v starter battery, from what I understand if the 12v battery is on it's last legs everything will act fine but the light will come on, of course the dealership should have checked that... but they don't always do things like that.
Most auto part stores around here will load test the 12v battery to see if it's good, they should also be able to plug in an OBDII reader and tell you what the other codes are.
Old 07-31-2014, 08:31 PM   #8 (permalink)
http://ecomodder.com/forum/showthrea...vic-13610.html A P1447 & P1449 means the battery is worn out. Its less than 10% of its original capacity. The P1449 means over heated battery pack.
Originally Posted by DOHCschwab View Post
Got any direct links to exact code translations on this site?
Old 07-31-2014, 08:44 PM   #9 (permalink)
After you get the codes, disconnecting the 12 volt battery for a few minutes will reset the car and may make it "driveable." Some IMA codes are not detrimental, like the one for "excess heat." But driving with those codes makes the car want to baby the IMA battery. Stopping assist or regen, or failing to charge the 12 volt battery. Your battery may still be capable of functioning normally, resetting the cars computers make it behave.
I try to be helpful. I'm not an expert.
Old 08-01-2014, 07:23 AM   #10 (permalink)
edit
