Old 11-27-2011, 08:24 PM   #1 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Thinner tires on original rim?
When I look at tires, one of the specs is the rim width range. My wheels are 15x5.5 inches, and the stock tires are 195/60R15. I planned on going with 195/65R15 because they are taller tires, but it looks like 185/65R15 will work on my rims also. These are the same diameter as the stock 195/60R15, but they are thinner tires by 10mm. I guess my question is would the 185/65R15's even fit? also, are the 195/65R15 or 185/65R15 better for fuel savings. last, will there be safety concerns with a thinner tire?
Old 11-27-2011, 08:49 PM   #2 (permalink)
Tire Geek
CapriRacer's Avatar
The affect rim width has on tire performance is very small provided you stay within the published allowable rim width range.
When it comes to fuel economy, a larger load carrying capacity is directionally better - but the affect is small. So, no, thinner is not better!
But, there is a HUGE range of values for rolling resistance between tires - up to 60%. So careful selection is very important. Just be aware that there is a technology triangle between treadwear, traction (especially wet traction) and fuel economy. Put another way, if you really go after treadwear, the result will not be the best fuel economy.
But with the recent tire price increases, it just may be that we have crossed the point where an improvement in fuel economy - at the expense of treadwear - does not result in an overall cost savings over the life of the tire. Does anyone have the old calculation, so we can update it?
Old 11-27-2011, 09:47 PM   #3 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I have 185/65R15 tires on 5,5 rims and they handle fine, better in rain and snow than fatter tires.
- Tony
Old 11-27-2011, 10:50 PM   #4 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Just check the rim width range for the tire size you are planning to purchase. The seller should have that information available with the tires.
Old 11-28-2011, 12:29 PM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Tire Size Calculator - tire & wheel plus sizing
will tell you everything about a tyre size.
5.5 rims will fit either size tyre.
Old 11-28-2011, 04:35 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I will try to make test to put 155/80R14 tire to 5.5" wide rim. Purpose is to get better aero. At least on my Lupo 3L 145/80R14 Bridgestone B381 ecopia vs Nokian hakkapeliitta R 175/70R14 the narrower tire is much better even the Hakkapeliitta R has better LRR factor (is lowest with Michelin XI2)
Wider tire gives much more drag than the RR can give benefit. I will also test 155/65/R14 Hakkapeliitta R later this winter so I know is the aero really the problem or something else. (rims have little bit different ET and are heavier etc...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 11-28-2011, 07:14 PM   #7 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
If you look at the specs for each size tire you will see that a 195 can have the same contact patch as some 225's. The size on the sidewall means almost nothing.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 11-28-2011, 07:17 PM   #8 (permalink)
Sippin' gasoline
btracing's Avatar
ecohok 2 - '94 Volkswagen Polo Steilheck/Breadvan
On my VW Polo I went from 155/70-13 tires to 135/80-13, on the same original rim (4,5J). It's skinny, but it drives pretty good now. First results I am expecting in en few weeks.
Old 11-29-2011, 07:04 AM   #9 (permalink)
Tire Geek
CapriRacer's Avatar
A couple of thoughts:
I've done some calculations of the affect of areo drag vs RR - and found that the increase in aero drag for wider tires is SMALLER than the improvement in RR. I suspect this is because tires are mostly shielded from the wind by the fenders (wings for you Brits!)
Another thought is that, tire size plays a pretty small role in RR compared to the difference that changing tread compound has - that is, different tires (even within the same brand) will have a much larger affect on RR than tire size will have.
Old 11-29-2011, 09:00 AM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
You should also notice that if you put wider tires to your car the tires arent anymore behind the bumber/wings. If they are narrower they might be too much inside...
I think that migh be the biggest reason for my bad fueleconomy with these Nokian Hakkapeliitta R. Should get also different ET rims. There are so many things that affect everything that its difficult say which fault the change is... For Nokian winter tires the outer edge of the tire is sharp and I have thought of grinding it round .
Soon I will have about 7 sets of similar aluminium wheels and will start doing my own winter tire tests which combo works best on my lupo.
