Old 08-21-2011, 11:42 PM   #1 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
UG help
ok i got my GF an ultra gauge for the birthday for her 06 charger. we got it installed and programed. but for some reason when she makes a trip turns the car off with no issue. but when she is ready to leave she has to un plug the UG to get it to turn on. So basically she has to unplug the OBDII and plug it back in after every trip. any ideas?
Old 08-22-2011, 01:32 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Per the UG manual, you may want to check the vehicle's OBD-II connector pins for corrosion. I'd run a continuity check on the power and ground pins for a poor solder joint, too.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 08-22-2011, 07:09 PM   #3 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
There are two modes in the UltraGauge that detect engine start. You need to change the selection most likely for it to detect engine start. Look it up in the manual. I gotta run!
Old 08-22-2011, 07:35 PM   #4 (permalink)
Red Light Avoider
pletby's Avatar
90 day: 46 mpg (US)
Had a moment:
Power on Detect mode
Bottom of page 34 in the Manual.
Menu->Ultragauge setup (version 8/24/10 or later).
"Mode 1 Will always detect correctly, but uses more power while the vehicle is off. This mode should only be used if Mode 2 fails detection.
Mode 2 is the recommended mode and uses less power while the vehicle is off. Mode 2 is the factory default. Mode 2 is ignored for vehicles with 9141 and KWP 2000 protocol."
Mode 2 does not work with my car (97 Ford Contour V6 Auto) so I had to select mode 1.
