06-11-2014, 12:31 PM
#21 (permalink)
Originally Posted by johnlvs2run
Well then the iridium plugs would increase mpg, due to faster pulses vs distance of coasting.
I never did pulse and glide, but anyway, the savings would come more from the longer lasting of the plugs than anything else.
06-11-2014, 02:29 PM
#22 (permalink)
Originally Posted by Old Mechanic
...make sure you adjust the valves if your're going to pull the cover anyway.
It was my impression that modern hydraulic valve lifters were self adjusting. Is this not the case? None of the cars I drive indicate a valve adjustment interval except for my motorcycle.
06-11-2014, 02:39 PM
#23 (permalink)
Hypermiler
This is a Civic, right? Changing the spark plugs is the easiest thing on these. Pop the hood, there they are in a row, right on top in front of you.
#24 (permalink)
My 94 had lash adjustments at recommended 30k intervals. Not sure aobut 99 but I think they still had lash adjustments.
http://www.civic-eg.com/causeforalarm/D16Y/index.php
regards
Mech
06-11-2014, 03:14 PM
#25 (permalink)
I had my then-girlfriend change the spark plugs on my Civic. If you change the wires, they always say to change one at a time, so you can keep the order correct, but I forgot that step, and we seemed to figure it out well enough.
It was amazingly easy.
06-11-2014, 03:42 PM
#26 (permalink)
...beats walking...
Automotive Hansel & Gretel's VISUAL "bread crumb" trail: Take a picture BEFORE you take anything apart...LOTs of pictures.
The Following User Says Thank You to gone-ot For This Useful Post:
06-11-2014, 03:55 PM
#27 (permalink)
A 4 cylinder is easy. It wasn't quite as easy on my 1973 Jaguar XJ12 12 cylinder.
06-11-2014, 06:13 PM
#28 (permalink)
...beats walking...
JAGUAR XJ12
• The physical layout/arrangement:
A↑ (right bank: 1A..2A..3A..4A..5A..6A)
← FRONT of ENGINE
B↓ (_left bank: 1B..2B..3B..4B..5B..6B)
• The firing order: 1A..6B..5A..2B..3A..4B..6A..1B..2A..5B..4A..3B
It's really funny what seemingly useless numerical sequences a motorhead will remember, like my 340/6BBL (LA) engine: 1-8-4-3-6-5-7-2.
06-11-2014, 06:28 PM
#29 (permalink)
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
On my civic, platinums were -5.78mpg. Iridiums were -2.83mpg. Best were the stock v-power. Pump neutral, but butt happier with indexing.
This is on a lean burn engine that is very sensitive to spark changes. Haven't tried swapping out since I added the msd though. Can, they're near new collecting dust on the shelf.
Shooting for 600 miles of range at 65-70 mph out of a vx.
06-11-2014, 06:31 PM
#30 (permalink)
Liberty Lover
acceleration
Is acceleration faster with platinum & iridium plugs?
