Old 05-01-2017, 11:38 AM   #11 (permalink)
I have used zip ties for years on my coroplast fairings. I make two holes about 1/4" (6mm) apart and start feeding from the back side. Since duct tape is not weather proof I will try Gorilla tape on the seams. Double sided tape works best when the surfaces are smooth.
Old 05-01-2017, 03:40 PM   #12 (permalink)
Looks like Grant found a pretty good KISS method if the 3M tape thing does not always work. Maybe using both will add peace of mind.
Old 05-01-2017, 05:33 PM   #13 (permalink)
A search of polypropylene adhesives yielded two Loctite products:
Power Grab Mounting Tape
Spray Adhesive Professional Performance
When I bond tarp material with a wire mesh core I use contact cement.
