Old 09-20-2008, 11:30 AM   #21 (permalink)
GreenMile - '00 Mazda Protege ES
90 day: 34.45 mpg (US)
As I said earlier: Your main concern should be about first finding your most fuel efficient tire, most of the best seem to fall in the 15-16" size. These tires have an overall lower average RRC (rolling resistance coefficient). Your RRC effects fuel economy significantly as this number is multiplied by the mass of the vehicle to calculate the total loss of energy.
Once you have an efficient tire it would be time to address ride height (as we already know that lower height improves both handling and aerodynamics) and then seperately deal with your gearing issues to maximize energy efficiency.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
Old 09-20-2008, 12:02 PM   #22 (permalink)
stinky - '97 geo metro lsi
90 day: 44.71 mpg (US)
i guess metrompg was wasting his time changing his tranny to get
1968 rpms at 50 mph on 13 in tires ( 155/80/13) instead he could have just put 16's on his car
Old 09-20-2008, 01:50 PM   #23 (permalink)
econ00b
green car - '91 honda civic hb dx
Originally Posted by guitarterry View Post
again what i was wanting to know from metrompg was why he used 155/80/13 instead of 145/82/12 tires and even taller gears.
I would guess its based on the availability of tranny gears to swap in. There most likely are very limited options, so he used a taller gear that was available in the trans, and used taller tires (the 155s) to make the gearing even higher.
Old 09-20-2008, 02:13 PM   #24 (permalink)
Red
Red's Avatar
Another thing to consider is tire selection for a 12" rim. For the most part we are all stuck buying what ever tires are manufactured. In a perfect world I'd love to run a 32x9.5x15" tire on my Jeep, but no one makes it. 13" and 14" rims and smaller tires sizes are slowly being phased out, so your choices in a smaller rim and tire selections drop.
In Darin's case I think he was shooting for the lowest RPM he could run without lugging the Metro. And he would have had the same final effect running 16s and some big arse tire as the gear swap. Only catch would be that he would be suffering from the effects of being under geared all the time. With the gear swap, he only takes a major hit when he is in his higher gears, otherwise he is accelerating more or less normally
Old 09-20-2008, 02:22 PM   #25 (permalink)
What does custom gearing cost. (just top gear) some of the money ive seen spent for questionable results. This would be a definate payoff. plus like metrompg said himself, there is disadvantages in the lower gears. this would be the best of both worlds.
Old 09-20-2008, 02:41 PM   #26 (permalink)
Originally Posted by Red View Post
Now Tire diameter, no idea why you'd want to run a 5" rim, you'd have brake problems and stuff. Bad mojo, but your call. The only benefit you'd have is that the tire would be super narrow compared to say a 14" rim and tire, and much less weight so its easier to turn. Depending on the aspect ratio of the tire, you'd still get sidewall flex. But if you are running at max load, you'll negate a fair amount of it.
Forgive me, I was bored.....
ITS AN EXTREME. Its suppose to be so over the top as to knowbody would ever confuse it with reality. ITS NOT FEASIBLE... JUST AN EXAMPLE...
Old 09-20-2008, 05:33 PM   #27 (permalink)
Red
Red's Avatar
I know, just messing with ya
FWIW I have heard that getting an new gear set made for a tranny costs around 1-2k. Most of that cost is due to R&D for the new gear.
Old 09-20-2008, 05:47 PM   #28 (permalink)
ur funny, not as funny ha, ha but funny as in *****
Old 09-20-2008, 06:04 PM   #29 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
If you want to save gas, keep your 4 cylinder transmission and swap in a 3 cylinder engine for a few hundred
Old 09-20-2008, 11:52 PM   #30 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Red -
That's what I was thinking, +$1K at the least. Now if your pal works for a custom gear maker like they have in the NHRA ...
CarloSW2
American Solar Energy Society
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 06:47 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
