Tire that makes electricty
https://autos.yahoo.com/blogs/motora...134602398.html
Tire that makes electricity??? Quote:
Interesting concept. That specific tire/wheel combo pictured wouldn't last long in a real driving environment with potholes curbs etc.
I wonder what kind of rolling resistance they will wind up with?
Remember, you can also put linear generators on your shock absorbers. Those don't make enough power to bother with, though. This may turn out to be a similar deal... -soD |
How does it transmit the power to the car? A bare end of a wire rubbing on a stationary plate at the center hub? |
It takes work to generate electricity. Every watt of electricity generated is added rolling resistance. The total increase in rolling resistance is equal to the electricity generated divided by the efficiency of generating that electricity.
It's a variation of the old perpetual motion scheme of connecting a generator to the front wheels to drive an electric motor on the rear wheels. |
I think that regenerative shock absorbers have a better prospect at being practical.
I agree that it doesn't seem practical. But the tyre is deflecting anyway, using this deflection to generate electricity will add resistance to the tread deforming, basically making the tread stiffer and reducing rolling res. Problem for us would be as you raise tyre pressure the energy generated will drop. |
The downside is that smooth roads would generate very little electricity, and regenerative shocks would be heavier than standard shocks. Regenerative shocks would be perfect for somebody driving on washboard gravel roads. |
Here is a different method: New nanogenerator might set energy-generating car wheels in motion
