tire shoping
well after just over 40k miles my 30x 9.5 r15 bridgestone duelers a/t revo's are down to the tread wear indicator.
http://www.tirerack.com/images/tires..._owl_ci2_l.jpg they seemed to roll at anything under 40 psi, but stuck to the road like glue. and were too soft, i got chunks on them going up a dirt road for about a mile. now it is time for a replacement. i think i am gonna drop down to a 235/75 r 15 )almost stock (225/75 r15 is stock) but alot more choices. this time i want a highway tread. the tire i think i like is a General Grabber HTS http://www.tirerack.com/images/tires..._hts_ci2_l.jpg but havnt located them locally yet. i did stop by sams club and was shown Radial Long Trail T/A by BFGoodrich. http://www.tirerack.com/images/tires..._owl_ci2_l.jpg for 440 installed, i have had them before(in a 31x10.50 r 15) but dont remember if i liked them. i also liked the weird tread on the Fortera by goodyear. http://www.tirerack.com/images/tires...tred_ci2_l.jpg but i dont know about them i want a tire that is llr "ish" that can fit on my truck, that is driven on highway 99% of the time with no load on it.:turtle: it also rains quiet abit here. ( if i need to tow or haul i got the 09) so what are you all opinions? i am open for any tire that is good. |
taco -
Here are mine : http://ecomodder.com/forum/showthrea...ires-2642.html http://ecomodder.com/forum/attachmen...1&d=1231739068 They do come in size 235/75 r 15 , but not rated at 51 PSI max like mine, only 44 PSI. Take note : Quote:
Also, someone told me that you can have high-pressure rated valve stems installed when you get new tires. I think someone who worked at a tire store posted this. If I had known about that, I would have spefically requested it. CarloSW2 |
Wouldn't going down to a narrower tire help FE quite a bit? Since you are going to run higher pressures a narrow tire won't roll over when cornering hard and will clear water much better than a wider tire.
I've gone to a much narrower snow tire and I haven't found a downside yet except the tires do feel a bit sloppy on dry pavement but I don't mind. If I want sharp handling I can put my autocross tires on during summer.... Ian |
Narrower vs stock width? Not "quite a bit".
well a 235 = 9.4, and i had 9.5 so it is not really narrower.
30 tall(old) vs. 29.1(new) tall so i want something to last. i got my revos on 8/28/06 and put a little over 40k on them, just going to work. |
The Green Seal Test showed the Long Trails to have the lowest rolling resistance coefficient of all the 16" truck tires. That is likely true on 15" truck-type tires.
i know i read that, and i think i may go with those, but i was trolling tirerack and found the general tires.
long trails http://www.tirerack.com/images/reviews/SurveyTabs.gif --23--80%--6.6--7.1--6.9--7.3--8.2--7.5--6.7--6.2--5.6--7.9--7.8--8.1-37,852,348 general http://www.tirerack.com/images/reviews/SurveyTabs.gif --1--100%-8.3--9.2--9.3--9.1--9.4--9.1--8.8--8.5--8.1--8.9--8.7--9.1-273,442 under the highway all-season but look at the mile difference. but i think i may go with the better brand. also the general have a treadware of 640 and weigh 34lbs long trails it dont even show them in my size but i have touched them? |
No doubt about it, the Generals are better all-around tires in your size. Have you ever considered Goodyear Eagle SR-As? Yeah, they are car tires, but they are terrific all-around tires.
It really come down to one question: How important is low rolling resistance to you as a parameter of performance? For fangs-out low rolling resistance in a bigger tire, the Long Trail has to be considered. If other parameters are more important, forget the Long Trail. |
i want distance, with good rolling resistance. like i said i drive over 30k a year.
the revos i have now i can fell the drag at anything under 35psi, like i said they were a soft tire also. u could dent them with your finger nail. |
well i ended up witl long trail touring, not the radial long trai. not what i exactly wanted but oh well. they seem to ride smoother than the revo's but i hope the height dont hurt my fe.
http://www.tirerack.com/images/tires...tour_ci2_l.jpg that is what i got. |
