Yeah, I remember building my own "powered" THING: A 3' x 4' piece of 3/4" thick plywood, with a 2" x 4" board bolted to one end and an old Briggs & Stratton 'side-crank' lawn mower motor bolted onto the other end.
The "clutch" was a 3-pully V-belt. tension arrangement. Push the board holding the front pully forward, tightening the V-belt around the motor pully and pully bolted to the inside of right rear wheel, and off you went.
Steering was with your feet; push the front-axle board to cant the front wheels left or right.
Brakes? Who needs brakes when you're young & immortal!
