Toyota Claims Bigger Engine are Better for Fuel Economy
I was just looking through some of the official Toyota videos on youtube when I happened to stumble across this explanation of some of the tech in the new Prius. I already knew that Toyota had made some changes to the engine to favor a more powerful, quicker Prius. Despite that, the car received a [...]Related posts:
More... |
I agree that to a point, a larger engine will give better FE. I have had several GM 2.8 and 3.1 MPFI engines in identical cars, and the 3.1 always gives better FE. The only difference between the powertrains is the piston stroke.
Same thing with some others, when you have an undersized engine for the vehicle, the FE takes a dump. Take a larger engine so you barely have to work it, and to a point you can get better FE. |
Use the standard issue (drag-race to the stop sign) nut behind the wheel and compare smaller to larger engine, the larger engine might win out on FE by virtue of the ECU not having to spend 90% of the time in non-stoichiometric fuel enrichment.
Install an ecomodder/ecodriver nut behind the wheel of the car and compare smaller to larger engine and the smaller engine probably wins every time. |
Hi,
I was at the Detroit show and saw the new Prius: Quote:
http://hiwaay.net/~bzwilson/prius/pri_power_200.jpg My NHW11 Prius has the 1.5L engine and you can see that the brake specific fuel consumption is falling off at higher rpm. This chart shows another effect, which we suspect is fuel enrichment at high power settings above 3,7500 rpm: http://hiwaay.net/~bzwilson/prius/pri_power_600.jpg The high power region is where cooled exhaust gas is added to cool the exhaust and allow higher power output with less fuel burned. At high power settings, the engine has to use a rich mixture to keep from burning out the catalytic converter. So the larger, 1.8L engine and appropriately improved hybrid transaxle lets the engine avoid higher, energy wasting rpms. With cooled exhaust gas, the engine continues into higher power settings but without the extra heat. What we don't know is if a similar system fitted to the existing Prius would provide a similar mileage improvement not counting the friction losses. BTW, the Otto cycle engines suffer pumping losses through the throttle that the Atkinson cycle avoids. What this means is what works with the Prius engine won't necessarily work with an Otto cycle engine. Bob Wilson |
A rich mixture is used to maximize power output and cool the intake charge in order to minimize the risk of detonation, not cool the catalytic converter, which has typical operating temperatures around 1500-1600F, right around the maximum EGTs SI most engines will make. Having the larger 1.8L engine and taller gearing could very well help out with SFC, although the four-stroke Atkinson cycle is exactly like the SI Otto cycle minus the delayed closing of the intake valve after the piston has started to travel upwards again. The four-stroke versions allowed Toyota to cheaply and effectively de-stroke their 1.5L engines for use in the Prius, unlike the original Atkinson cycle that supposedly used a modified crank and had the intake, compression, power, and exhaust strokes in a single turn of the crankshaft.
Hi,
Bob Wilson |
Well I'll be! I've never though about starving the cat of oxygen but that certainly shows me! ;)
Clearly the 1NZ-FXE would have lower fuel consumption than a normal 1NZ-FE since it's effectively destroked, which improves fuel consumption through fewer throttling losses, but also caps torque output across the powerband, and while the higher expansion ratio may help it doesn't appear to help a whole lot when we scale the output compared to other engines. Capping the torque output by reducing the effective compression ratio and the offset crank are where most of the gains appear to come from based on comparing it to decade+ older/larger engines from Toyota. The only way to determine how much the higher expansion ratio helps would be to compared the 1NZ-FXE to a version destroked to have the same effective compression ratio. In terms of low drag vehicles cruising in lower power regions, that isn't much of a problem where a hybrid cycles on and off and stores power to be used in a battery instead of operating at a steady/lighter load. This, along with the taller gearing, is what Toyota can increase the engine size in the new Prius and increase or keep mileage the same. It's the same idea behind P&G. It doesn't matter how poor low load engine efficiency is if the engine is almost never operated there. Granted, their is a loss from dumping energy into the battery pack and out the motor, but as long as that loss is less than the increase in BSFC, then there's no reason not to do it. Diesels have problems with NOx formation because of CI, not necessarily the higher CR. SI engines can have the same CR as modern diesels, but low engine out NOx because the A:F mixture can be distributed relatively homogeneously, which minimizes hots spots during ignition. CI engines otoh see ignition start more or less when the bulk of fuel is injected. Modern versions tend to run a bit richer to cool ignition and prevent as much NOx from hot spots during ignition. Anyway... Variable valve timing almost certainly won't get a SI engine near a CI engine in terms of overall fuel consumption/load, that's something we need HCCI, or something similar, for. On the plus side, GDI gets closer at low load, but that's the best in use implementation I've seen so far. |
When you get a chance, I'd recommend getting a copy of SAE 2004-01-0064 for this quote, "As a result, the minimum specific fuel consumption of 225g/kWh has been achieved. . . " (pp. 7.) This paper is the source of the first graph and does an excellent job of showing the specific systems in the Prius. More importantly, it shows how the Continuously Variable Transmission keeps the engine at the best BSFC over a very wide, rpm range (the operating range line on that first chart.) This operating line is the problem the old 6-banger could never solve with existing transmissions. Quote:
As the expansion ratio increases, the stress on the piston, rod, crank and cylinder head goes up right after ignition. It is equally likely that the 13-to-1 ratio seen with the 1NZ-FXE is a mechanical limitation. They didn't want to add the additional metal needed for a higher expansion ratio that might cause the engine to approach diesel weights. Bob Wilson |
Makes sense to me that if a guy were to keep putting in a smaller and smaller engine for a job that at some point the fe starts getting worse. Optimal piston speed might come into play here, although I admit I haven't done all my homework on that.
SVO, why don't you just say what you're going to say HERE? |
