Old 03-30-2016, 09:51 PM   #11 (permalink)
Thanks for the info, I was wondering if it would be possible to get ScanGauge data on an ODB1 vehicle somehow. (In my case, a 1991 Toyota Corolla.)
Old 03-31-2016, 05:06 PM   #12 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
It looks like if you have a TE2 pin on the diagnostic connector, you have TDCL.
I'll do a cleaner write up when documenting Project E. Currently working on a Bachelor of science in Electrical Engineering so time is tight. I have the material, just no time to track everything down.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following User Says Thank You to H-Man For This Useful Post:
BillyBob251 (04-04-2016)
Old 07-10-2016, 08:21 PM   #13 (permalink)
hi
looks like a very nice app
but what capacitor is needed? is there a specific one with a range of 1.5-3.3 or can u choose from either 1.5, 2.3, 3.2 etc?
and do you have a video of this thing in operation?
Old 07-14-2016, 07:19 AM   #14 (permalink)
and what voltage is the capacitor supposed to be at? 12volts or something else?
Old 08-22-2016, 12:33 AM   #15 (permalink)
Originally Posted by jimmy6 View Post
hi
You can choose. I just used a random cap that was in the capacitance range but you may want at least a 12V cap (voltage can be higher but not lower).
