Old 09-13-2013, 05:46 PM   #11 (permalink)
Originally Posted by night9 View Post
My question would be Is there an EV only mode? Then you could have the best of both performance when want it and efficiency.
I would imagine so. The electric drive isn't physically coupled to the gas engine at all.
The Following User Says Thank You to Daox For This Useful Post:
night9 (09-13-2013)
Old 09-15-2013, 03:26 PM   #12 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
As the owner of a 2007 Yaris this is my dream Yaris hybrid:
add the following to the stock Yaris
1. 1 meter long boat tail
2. full under tray
3. improved front end aero...
4. Cd of under 0.20
5. 2 rear wheel 10kw motor/generaters
6. 100kg plug in battery pack
7. all the controlers & stuff...
For a resulting FE of 2.5 L/100km [94 mpg]...& preformance to boot
Old 09-25-2013, 02:41 PM   #13 (permalink)
I'm a fan of the 1nzfe
Old 10-12-2013, 09:04 AM   #14 (permalink)
Motorcycle
Motorcycle
In thinking about the rear wheel hub motors, it occured to me that the more powerfull the hub motor/generate the heavier it is. the other question is how and when would AWD be of use? Low traction conditions such as snow, ice and wet mud . This would only need low HP, on the order of 3 - 6 KW [4 - 8 HP] per rear wheel. The other advantage of this type of layout is it is independent of the gas/diesel engine and can be programed for all sorts of things...
