Old 06-23-2012, 11:44 AM   #31 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I disagree. Folks need a little training, and I stand by my statement. Without it they are an accident looking for a location. No WDH will save them from a lack of experience.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-23-2012, 11:46 AM   #32 (permalink)
90 day: 19.36 mpg (US)
"Training" was already stated. But there is no substitute for best equipment (which also means hitch rigging set up according to formula). Anyone, novice or pro, is better off with such in any and all cases.
Old 06-23-2012, 11:50 AM   #33 (permalink)
skyking's Avatar
I did not find training stated.
Not all of us were born backing a trailer and hauling a load, as did you and I.
That is my main emphasis. All the fancy equipment on the most modern trailer is worthless with out that. IF you are within your hitch requirements of the tow vehicle, and have a properly loaded trailer the WDH is a great convenience but not a requirement for safe operation.
Note the hitch requirement statement. Most rigs come with a standard class 3 with 500 tongue/5000 maximum trailer weight WITHOUT WDH.
So following your class 3 standard hitch requirements, you will have a WDH with a typical travel or car trailer.
2003 TDI Beetle
2002 TDI Beetle
Old 06-23-2012, 11:52 AM   #34 (permalink)
" . . Same for a tow rig. The dynamics need to be experienced to find out how little one can actually do (in accident avoidance) to drive home the need for certain principles to apply first."
Old 07-04-2012, 09:39 PM   #35 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
well i managed to get home.
ive had many exciting things happen on this trip.
like oh little things like a fan belt, water in fuel warning, WVO short fall, severe side winds and head winds felt like gust to around 70, 105F heat with very high humidity (no A\C), axil shaft sliding out. you know little stuff like that....
ive found one of the best safety devices is your hazard lights.
just slow to 40/45 and go with the hazard lights
Planetisuzoo.com • View topic - Planet member broken down & stranded
IsuzuPup.com • View topic - daves grand adventure, June 2012
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
The Following User Says Thank You to trooper Tdiesel For This Useful Post:
aerohead (07-05-2012)
Old 07-05-2012, 07:19 AM   #36 (permalink)
Read the links . . quite an adventure. Bet you won't be moving to the South, willya?
Old 07-05-2012, 07:45 AM   #37 (permalink)
No way!!!!
Ill take damp dark and rainy over that any day.....
Old 07-05-2012, 08:28 AM   #38 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Seems like you two were a good match, one mad enough to take on this kind of trip, and the other mad enough to come to the rescue of a stranded stranger he had never met, hundreds of miles away.
Nice one
What made the rear axle fail ?
Old 07-05-2012, 11:15 AM   #39 (permalink)
what made if fail is rather odd, and i dont under stand it totaly.
i know i found the vent tube completely plugged, mix that with the added stress of towing the high temps and a tale pipe leaking a good 20% around the axil that made the oil seals fail on the axils.
the oil just takes the path of least Resistance.
but how that made the axil shaft come out is very odd.
the only thing i can come up with is, the extra high temps let the locking nut get loose, thats the only way for it to come out is for the locking nut to come loose.
or just by random chance it just happened then.
Old 07-06-2012, 01:00 AM   #40 (permalink)
skyking's Avatar
glad you made it back! Still reading the adventures......
2003 TDI Beetle
2002 TDI Beetle
