Old 05-18-2009, 12:14 PM   #11 (permalink)
janvos39's Avatar
jvsgears - '14 Skoda Octavia
Team m8
90 day: 52.47 mpg (US)
Manual actuated clutch on Burgman. I think this can be done by making some special shaft parts for a clutch out of a bike with manual gearbox. Probably the actuation of the clutch has to go through the center of the shaft due to the location of the external bearing for the shaft.
Another thing is the load on the clutch mechanism. Since you cannot put the gearbox in neutral, this mechism must contain a decent bearing.All the time for a stop the clutch needs to be used.
Old 05-18-2009, 09:14 PM   #12 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
This is true. Although I would already the lever in place if I were to go with a hydraulic clutch, merely combine the 3 braking systems into the right lever and use the left for the clutch.
I needs to get me a big giant socket to get that clutch loose.
Old 05-20-2009, 12:39 AM   #13 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
The CVT on my Honda Big Ruckus is so draggy in engine-off coasting that I hate it.
Old 05-20-2009, 06:28 PM   #14 (permalink)
They're all like that because...
*drumroll*
They're dragging the engine.
Also, unless your Ruckus is FI, turning the kill-switch off saves exactly zero gasoline. Carburetors continue to pump gas as long as the engine keeps turning.
Old 05-20-2009, 07:30 PM   #15 (permalink)
Hydrogen Nut
Ptero's Avatar
No. The coasting technique for a Big Ruckus requires slowing to 10 or 15 mph and killing the engine (and the electric fuel pump). This way the belt does not turn the engine when coasting but it does drag on the clutch assembly, significantly degrading the efficiency of the coast. I have also considered using a larger belt with a spring-loaded idler that would allow the loop to ride off the rear face when released for coasting.
Old 05-20-2009, 08:25 PM   #16 (permalink)
Same, although I just kill the engine at speed to drag me down anyway, as about the only time I can really kill the engine aside from hills, is when I have to slow down for traffic.
I would suspect you would throw the belt off quite often. It also presents the problem of not being able to bump-start if needing to be running again. Which can wear on the battery, unless you've done like me and put a proper starting battery in.
Old 05-20-2009, 08:33 PM   #17 (permalink)
Hydrogen Nut
Ptero's Avatar
No problem is apparent with this coasting technique. I've done it occasionally over several thousand miles. Even pulled the cover immediately afterwards the first time to check for point belt wear. Nothing. I regard the technique as harmless. You can also restart the engine without stressing anything below 20 mph. "Bump start" is not possible. I have not tried to start the engine at speed.
But due to the drag, there is little opportunity to receive a mileage gain except on long, steep runs.
Also, it is not possible to "throw the belt." You would have to break it.
Old 07-21-2009, 06:12 AM   #18 (permalink)
Well, an update on mine... I took out the rollers again, and weighted the 4 I hadn't previously. Now all are 25.9 grams, +/- 0.1 gram. Clutch action didn't change significantly as it did the first time, so I'm guessing cleaning out the whole mess caused my clutch to change.
The clutch shoes are nearly done, so I'll be replacing the clutch at some point in the near future when funds become available. I'll probably invest in a Union Material HiT clutch, and see if they can't modify it for a manual control.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Suzuki Burgman modification (aerodynamics + gearing mods) janvos39 Motorcycles / Scooters 165 10-27-2014 05:20 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 8 09-19-2014 02:42 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
The Suzuki Swift is still a super sweet car! SVOboy General Efficiency Discussion 15 11-22-2009 11:17 AM
