EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Trouble getting a VSS signal (https://ecomodder.com/forum/showthread.php/trouble-getting-vss-signal-34573.html)
nordic 11-22-2016 06:46 PM
I have a 1988 Honda Prelude that currently gets about 33 MPG highway. I just recently attempted installing an MPGuino. I don't have much experience with electrical work so this is a fun project.
I have everything connected and working with the MPGuino except the VSS signal. A couple guides online indicate that the ECU B10 yellow/blue wire is a VSS signal. The MPGuino does not read a signal from this wire.
Something else online suggested using the ECU B16 wire, but the schematics says that is the crankshaft sensor ground. I tried it anyways. I got a signal but it definitely was not the VSS signal.
Since I can't get a VSS signal from the ECU wires I thought I should go direct to the source. I can't find the VSS sensor on the engine though. Here are some pictures of my engine.
https://i.imgur.com/j11Wjyc.jpg
https://i.imgur.com/ZAbobpp.jpg
My question for the Ecomodder experts, where should I get a VSS signal?
LittleBlackDuck 11-23-2016 02:52 AM
VSS sensor is generally on the gearbox. Google shows it as being on top of the transmission and having a black plastic connector on top of it.
Simon
California98Civic 11-23-2016 01:05 PM
Are you certain there really was a electronic speedo then? The civics were still cable driven until 1992. Maybe the Prelude had more features. Maybe it had another way of reading speed for the ECU but I doubt that.
nordic 11-23-2016 03:38 PM
By what I have read it has a mechanical magnetic sensor that sense an electrical signal. I have found posts of other people with 3rd gen preludes installing MPGuino's.
LittleBlackDuck 11-23-2016 04:59 PM
That tallies with what I have seen. Two places remain for the fugitive VSS sensor - inside the speedo and on the gearbox where the speedo cable connects.
Have a look at this thread as it shows thew VSS sensor and also the gearbox clearly. In your second photo it should be buried somewhere under the distributor and on the top of the gearbox
Simon
nordic 11-23-2016 05:41 PM
Simon
I don't see a link, could you maybe PM it then.
LittleBlackDuck 11-23-2016 06:59 PM
OOPS! My bad - did not paste correctly. :cool:
1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap - Honda-Tech
Simon
nordic 11-23-2016 07:38 PM
That looks nothing like the VSS I was looking for. My googling gave me a different looking VSS.
LittleBlackDuck 11-23-2016 08:00 PM
Hope that helps
Simon
California98Civic 11-24-2016 12:33 PM
Some 3rd gen Preludes have cable, some have electronic. You can buy replacement cables for third gen Preludes from RockAuto and other major carriers. I'll bet diff trim levels had diff specs... you need to follow the check this guy recommends in this Prelude forum thread:
"To check, just look down at the top/rear edge of your transmission bell housing, near the shift linkage. If you see a box with wires, it's electronic, otherwise you'll see a huge cable. Have a look, it's not hard to differentiate them."
Broken speedo cable...easy to replace? - Honda Prelude Forum - PreludeDriver.com
