Old 11-05-2015, 01:59 PM   #1 (permalink)
Truck Tire Size for low RR
I tried searching but not many threads for 2500HD pickup tires
Does a larger wheel with smaller sidewall help or hinder rolling resistance?
Which one of these wheel sizes would likely have the lowest rolling resistance of these sizes in the same tire (Michelin LTX M/S 2).
265/75r16, 48lb tire weight, 31.7" tall, 80PSI max
265/70r17, 48lb tire weight, 31.7" tall, 80PSI max
265/60r20, 50LB tire weight, 32.5" tall, 80PSI max
Thanks!!
Old 11-05-2015, 04:27 PM   #2 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
My guess is, given the same compound, pressure and width, the taller tire will give the lowest rolling resistance as it will have the least sidewall deflection for the tire footprint.
I'm not coasting, I'm shifting slowly.
Old 11-06-2015, 10:23 AM   #3 (permalink)
Tire Geek
CapriRacer's Avatar
Tire rolling resistance is way, way more dependent on the make and model of tire than on size. In other words, tire size plays a small role in RR.
In other words, there is no point is going smaller in trying to achieve better fuel economy.
PLUS - the diameter of a tire will affect the overall gearing - larger being better. So it is good if you can fit a larger diameter under the fenders (and that is larger overall diameter, not larger wheel diameter!)
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
