Old 10-06-2012, 05:13 PM   #11 (permalink)
When considering the flotation of tires, comparing skinny vs. wide, always remember what the letters "PSI" mean and that the "P" is fixed by the weight of your vehicle.
Work From Home mod has saved more fuel than everything else put together.
Old 10-07-2012, 09:56 PM   #12 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
But you also have to remember that flotation and traction are two different animals.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 10-08-2012, 05:21 PM   #13 (permalink)
90 day: 19.36 mpg (US)
On a half-ton truck I'd avoid high load index tires (Load Range E). Stick with original size range as well, but in an LT designation.
The trade-off between LRR truck tires -- let's designate closed shoulder "highway rib" tires as such in the interim -- and traction tires needs to be cleared up by the OP as to whether low-traction but high miles/high mpg tires are a good choice.
With so few miles to accummulate over seven years (projected tire life) I don't think this is going to matter in any significant way.
Old 10-09-2012, 11:59 AM   #14 (permalink)
Team Pontiac
I have done a bit of driving this week with my new tires and they make the truck work harder all the time.
I did the math and I should only be losing ~6% of my rear wheel power. It does not sound like much, but it is noticeable. Climbing hills is harder and I often have to downshift, but level ground is not too bad. Getting up to speed takes more effort and time. I had a hard time going 60 mph with a load of wood on Saturday.
I had 235-80/16 on there before and it felt fine. The new ones should only be a hair bigger, but they stand 2+ inches taller. I think it is the deep tread that makes them a good inch taller alone.
I think this whole problem will get better as the tires wear, but I will be getting smaller tires when these are gone.
1991 F-250:
Old 10-11-2012, 03:56 PM   #15 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Want a bouncy ride? Run load range E truck tires on a 3200 pound Jeep.
