Old 08-03-2009, 10:46 PM   #11 (permalink)
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
All of my tanks are filled to the same level, at the same station, with the same pump every time. I fill to the brim for consistency. How is this not valid?
Old 08-04-2009, 12:05 AM   #12 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Air bubbles in the tank. I get over half a gallon variance from tank to tank taking the same measures.
Old 08-04-2009, 02:39 AM   #13 (permalink)
Not wearing pants
I don't know about getting a half-gallon variance due to air bubbles in the tank, but for me, it still wouldn't matter. I do my fill-ups the same way, right to the very brim each time, same station, same pump. If I go 685 miles on a tank, and put in 38 gallons, I get 18.0mpg. If I suffered from massive air bubbles in the tank and could have actually fit in an extra half gallon of fuel, then I would have only actually gotten 17.8mpg. 17.8/18.0 = 99% I think that's close enough, especially when I don't believe in half gallon bubbles.
Old 08-07-2009, 08:48 PM   #14 (permalink)
Even tho there are air bubbles in the tank/fuel they will be consistent as long as you fill up at the same rate with the pump every time..........which I do.
Old 08-08-2009, 02:06 AM   #15 (permalink)
Not wearing pants
Good point!
Old 08-10-2009, 12:51 AM   #16 (permalink)
DieselMiser
ConnClark's Avatar
Not true. When you fill it to the brim the air bubbles that gurgle out of the tank are what determine the final rate at which fuel flows into the tank. There is no way to get the gurgling to be consistent.
Even if find a way to to fill it the same each time you would still have too much variance in the road travel draw any valid conclusions with just one tankfull.
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Psychological Ways of Saving Fuel Wayneburg General Efficiency Discussion 22 06-06-2008 09:24 AM
