Old 06-21-2014, 01:59 AM   #21 (permalink)
wreck front - '98 honda civic hx
Originally Posted by backpacker3 View Post
My car will start in neutral. I've never tried it while driving though or in any other car so I don't know if yours will do the same
My 1998 accord starts in neutral I tried it today.
Old 06-07-2019, 10:15 PM   #22 (permalink)
Tahoe 2020 - '08 Chevy Tahoe H
90 day: 20.75 mpg (US)
Originally Posted by saunders1313 View Post
I've heard some posts saying that you shouldn't turn off the engine while coasting if you have an automatic. The only reason that I've found for this is that the transmission pump turns off. Are there any problems that could arise from turning off the engine? I P&G a lot and I'd like to start turning off the engine during long glides.
Overheating the transmission is a real risk..
Need an AUX pump to keep the fluid moving and lubricating..
Old 06-07-2019, 10:27 PM   #23 (permalink)
mpg_numbers_guy's Avatar
Insight - '06 Honda Insight MT
Gen-1 Insights
90 day: 88.27 mpg (US)
Never turn off an automatic transmission to coast. The little fuel consumption savings aren't worth the cost of transmission repair or replacement.
And since we're on the topic of starting in neutral, my '04 Civic auto I used to have would not start in neutral.
2006 New Formula Red Honda Insight MT, 272k: (Build thread)
Old 06-16-2019, 10:03 AM   #24 (permalink)
I am a big fan of EOCing....a manual.
I am not at all a fan of doing it with any auto. Even if it does not harm the trans.
It simply comes down to the fact that manual restarts can happen in an instant to restore power steering/brakes. It takes longer with an auto, if it is possible at all.
The only way I might consider it is if there was no traffic around me at all.
Old 06-16-2019, 11:39 AM   #25 (permalink)
Any car that the factory designed to be flat towed can coast in N engine off without fear of damaging the tranny. Cobalts are and I think the models before it were as well, back to the Saturn SL's. Electric Power steering the in Cobalt address the other issue.
The 2010 turned it's self off driving down the highway with cruise set at 55 a few days ago, just slipped it into N hit the key and it's running again.
Old 06-18-2019, 09:28 PM   #26 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
grayOS (personal use) - '19 Mitsubishi Outlander Sport ES
90 day: 30.71 mpg (US)
I had an issue coasting in my (now ex) wife’s 2006 Ion, using the 4T45 transmission... in theory the transmission can handle it but the car wasn’t programmed to accept the car moving and zero trans pressure (from engine off) as an acceptable condition so it threw a code and put the trans in some kind of limp mode... I cleared the code and the trans went back to normal but I learned that day that not all vehicles can be EOC’d even though their components *should* handle it...
My current Ecotec project...
My last Ecotec project...
Old 06-18-2019, 11:09 PM   #27 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 15.11 mpg (US)
Originally Posted by roosterk0031 View Post
The 2010 turned it's self off driving down the highway with cruise set at 55 a few days ago...
2010 cobalts were part of the ignition recall iirc
My 99 Saturn was supposed to be fine for flat towing, only issue I found was that the cruise control didn’t work if I eoc’d w/o coming to a stop, until the next time I actually stopped.
Old 06-19-2019, 12:52 PM   #28 (permalink)
Yeah the cobalt have had their ignitions replaced, thinking back on that occurrence, there is a pretty big bump in the road right there and I have more keys than normal on my key chain, and that key is a fairly new walmart replacement, my son has been driving it with the original key and fob only and no reoccurrences. It also had a car with lock show up on the dash around that same time that I think is gone now.
MetroMPG mailbag: how to keep SG live when engine off? MetroMPG Instrumentation 6 10-17-2011 04:44 PM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 02:42 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
