EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   Two 70+ MPG tanks in a row! (https://ecomodder.com/forum/showthread.php/two-70-mpg-tanks-row-29351.html)
Gasoline Fumes 06-27-2014 12:43 AM
http://ecomodder.com/forum/em-fuel-l...vehicleid=3248
http://ecomodder.com/forum/fe-graphs/graph3248.gif
ecomodded 06-27-2014 01:08 AM
Stupendous , did you use high gear low rpm driving and neutral coasting to get it ?
Good Job , though your pushing the envelope
Gasoline Fumes 06-27-2014 03:01 AM
Lots of engine-off coasting. And yes, very low RPM. I upshift at 2000-2200 RPM. I'm usually cruising at 1500 RPM in 4th gear. Which is about 40 MPH. Not using 5th gear much these days. It's too tall! I need to be going at least 45 MPH to use 5th gear on flat ground. Great on the highway though! Also very little braking or idling.
cowmeat 06-27-2014 04:51 AM
I had that same exact car about ten years ago, same color, minus the rust, and an automatic versus stick, and I barely broke 30 mpg.
Looks like you've done a lot to it on your page. Out of all the stuff you did, what brought you the most gains?
Congrats! No telling what you'll be able to get in the Metro!
elhigh 06-27-2014 10:27 AM
That is cuh-RAZY great mileage. You're tootling around at modest speed and ultra-low revs, that's how it's possible.
That little engine/big space paradigm makes the Civic Wagovan one of my all-time favorite cars, I've always loved those. Although I think I would probably prefer the AT4WD model, and have to give up the great mileage as a direct result.
Nice, nice work.
Daox 06-27-2014 10:50 AM
Very nice work!
MetroMPG 06-27-2014 10:52 AM
Fun! More congrats here.
Wagovan was like the pre-Fit, minus the fancy back seat.
PaleMelanesian 06-27-2014 03:48 PM
Great work!
Almost to the inch.
2009 Fit - 1990 Civic wagon
power 117 @ 6600 - 92 @ 6000
torque 106 @ 4800 - 89 @ 4500
width 66.7 - 66.1
length 161.6 - 161.7
height 60 - 56.1 (if you flatten the Fit's arched roof it's almost identical)
wheelbase 98.4 - 98.4
weight 2489 - 2335
headroom f/r 40.4/39.0 - 39.4/38.0
leg f/r - 41.3/34.5 - 41.2/33.2
shoulder 52.7/51.3 - 53.5/53.5
hip 51.5/51.3 - 50.1/52
cargo 20.6 - 21.5 cu ft
epa mpg 27/33 - 27/31
Cobb 06-27-2014 05:04 PM
You increased your fuel economy by not using as much gas?!?!?!? :eek:
Interesting......
Originally Posted by Gasoline Fumes (Post 432322)
Lots of engine-off coasting. And yes, very low RPM. Also very little braking or idling.
mbolton1990 07-08-2014 12:07 AM
Wow.
I'd love to put a HF trans into a Wagovan,talk about the best of both worlds...
It'd make a awesome vehicle to see the country in.
And of course put in some 2G Prelude seats.
Keep it up,very impressive!
