Old 07-01-2010, 10:43 AM   #101 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The big difference is the Kill-A-Watt will capture inefficiency in the charger and the batteries.
FWIW, my NiMH charger's 48V power supplies are 84% efficient, and the cells are reportedly near 92% efficient in the "bulk charging" regime. They approach 0% efficiency as the "topping off" phase nears completion. Google tells me lead acid efficiency varies greatly, but is probably less than 92%.
Old 07-01-2010, 01:52 PM   #102 (permalink)
Call: 425-788-9293
Answers
I want to clarify the data on my Watt Hours per miles. When I say 130-140 WH/mi that is at a constant rate cruising at 65 mph on the flat. When I said 177 WH/mi over the first 171 mi of my trip, it was an average that included several stops and starts that were as high as 1000 wh/mi for the first mile of a restart. The reason for the high wh/mi on the starts is because the motor is really inefficient taking off from a stop when it is geared for 71 mph on the top end because there is not a transmission (if I had a transmission I could probably drive it in a manor to reduce that number). The original 192-wh/mi figure was an average over the whole trip, including starts and stops and a conversion from amp hours to watt hours that was not accurate, it did not account for large voltage sags towards the end of my run. I have two amp hour meters set on amp hours not watt hours because I do all my battery testing in amp hours, in order to more accurately gauge differences between battery weights. Therefore I am more familiar with amp hours, verse watt-hours.
Another thing I would like to clarify is that my goal was to build a vehicle that can go 200 miles on a single charge with a speed of 60-65 mph for 85% of the miles, for under $3,000. I accomplished this goal. Because of my $3,000 limitation I made a lot of compromises in the chassis design hoping that the aerodynamics of the vehicle would make up for those inefficiencies. Inefficiencies such as front wheel bearings that rumble, back tires that are 10 years old and misshapen, single speed dual series motors (that were $100), no re-gen and inexpensive Curtis controllers.
Other facts about the vehicle:
I had an arcing issue with the right motor a month ago on the 80-mile Lacey trip. So I retimed the motor for that particular direction. Since the motors run in opposite directions I some how over looked that and did not get it timed properly. So I retimed the motor, for some reason one motor pulls a lot more current at low rpm and the other motor pulls more current at high rpm. It could be that the controllers are not identically matched to one another, or that the motors still are not timed properly, or a variety of other things. I do have a trim pot between the two motors to balance them out and make corrections on the two amp hour meters on the fly. The first 80% of the trip I was keeping the amp hours equal from one motor to the next, the last part of the trip I was going by voltage sags in the two packs, the difference in capacity between the two wet led acid battery packs is because some of the strings were more then 10 years old and therefore had different capacities. Out of the 10-72 volt strings, I tried to match all the batteries within the string.
As far as the chassis strength and the lack of noticeable triangulation:
The chassis that was added to the car was .065 x 1.5 in mild steel square tubing. The triangulation on the rear boxes is done with a 3/8 thick Kevlar composite sheeting that makes the frame stronger and lighter then you could possibly imagine.
Regarding the charging inefficiencies, they do exist. But are not my main concerns since I am a car builder, not a charger builder. I do not want to spend my time on the charging inefficiencies when other people are more experienced in those areas. I will leave that up to somebody else.
If anybody has any questions about my car or my 201-mile trip do not hesitate to call me. I live on the west coast, call anytime between 9am- 11pm. I always answer my phone or return a message. It is much easier for me to answer questions or discuss matters over the phone then write them down.
I chose this set up for economical reasons, not because I don’t have the money, I just wanted to stay within my goal. I have 8 in advanced DC motors and better controllers in stock, I just chose not use them in order to stay within that budget.
I hope I haven’t confused you further.
Dave Cloud
425-788-9293
Don't guess when you can know the facts.
The Following 15 Users Say Thank You to DaveCloud For This Useful Post:
aerohead (07-01-2010), dcb (07-03-2010), fusion210 (07-08-2010), groar (07-01-2010), HHOTDI (05-31-2012), KamperBob (07-01-2010), NachtRitter (07-01-2010), NeilBlanchard (07-01-2010), Piwoslaw (07-02-2010), Ryland (08-15-2011), Scimitar (08-12-2010), ShadeTreeMech (07-12-2010), SVOboy (01-20-2011), TEiN (07-06-2010), The Toecutter (07-14-2010)
Old 07-01-2010, 02:08 PM   #103 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Exactly. That could be bad for someone focused on one area only. An electric car is a whole system. Batteries and motors are important but they are only some of its parts. Charging is not free nor perfectly efficient. All wires carrying high amps incur line losses both during charge and draw. Wall measurements take that all into account to determine what is practical in a real operating cost per mile basis. I would not be surprised if some of the variation reported between EV folks is just different measurements.
Cheers
KB
Old 07-01-2010, 02:30 PM   #104 (permalink)
Left Lane Ecodriver
Hello Dave, and thanks for posting.
I do understand your ambitious project goals, and congratulations on meeting them. My own goals are a little different, but your car is very interesting to me because of its excellent aerodynamic drag, and the fact that it is or could become an inexpensive EV with enough range and top speed to be practical. What would it take to make the Dolphin your daily driver?
I'd love to see amp readings at 10mph and at 70mph, preferably bidirectional to sort out gravity. This would result in CdA and CRR figures, for real this time. I expect the CdA figure to be better than anything a forum member has ever put full-sized license plates on.
Old 07-02-2010, 10:51 PM   #105 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
range.....
did he mention what his range was on a full charge? lead acids are so heavy and the others are so expensive. donations for a better battery source would be an advantage. my hat off to him. love it.
Old 07-02-2010, 11:16 PM   #106 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
He recently managed 200 miles, mostly at freeway speeds, on a ton of lead in average condition.
Old 07-03-2010, 12:19 AM   #107 (permalink)
That has to be the sexiest car I've ever seen.
The Following User Says Thank You to funkybunk For This Useful Post:
NeilBlanchard (07-03-2010)
Old 07-03-2010, 12:31 AM   #108 (permalink)
Copy that, all you guys who say the significant other won't let you fit fender skirts? Go all the way and win big.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Old 07-08-2010, 10:10 AM   #109 (permalink)
Old but Gold - '87 Volkswagen Jetta CSL
90 day: 30.87 mpg (US)
Really inspiring to see stuff like this. I'd drive that for sure.
Old 07-08-2010, 08:29 PM   #110 (permalink)
An MP3 of an interview with Dave Cloud, all about the Dolphin, on EV World:
http://www.evworld.com/evworld_audio/david_cloud.mp3
(click on image for link)
Please note, dcb that Dave Cloud seems to agree with you on the superiority of a simple direct drive parallel hybrid. However, he seems to be basing this on the Chevy Volt, which is a lousy implementation serial hybrid. I think we need to get some hard numbers from the FVT eVaro and compare.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
