Old 12-25-2014, 12:03 AM   #1 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
ultragauge: DFCO disappeared
My ultragauge has always showed 9999 instant mpg for DFCO, but now shows less mpg for coasting in gear than coasting in neutral, for example 150 mpg coasting in gear and 225 mpg coasting in neutral.
The bank 1 O2 sensor goes to 0.000 immediately when coasting in gear. I've not checked the bank 2 O2 sensor yet. Any ideas why instant mpg doesn't show 9999 anymore, and am I still getting DFCO?
Old 12-26-2014, 10:53 AM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I can't tell. Any way to read injector status?
Transmission type Efficiency
Old 12-26-2014, 07:33 PM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I'd have to suggest it's a software error in the gauge. Reset time
Old 12-27-2014, 08:46 PM   #4 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Are you using the 8 page gauge? Only the 4 & 6 gauge pages display DFCO consistently on mine.
Old 12-27-2014, 10:07 PM   #5 (permalink)
Liberty Lover
j12piprius's Avatar
cause & solution
Thanks for the ideas and suggestions. The issue occurs with both 8 and 6 gauges per page. Both of the O2 sensors go to 0.000 immediately when coasting in gear.
The issue occurred after changing Pwr off Retries from 5 to 33, and went away with the setting back on 5. Increasing to 22 brought the issue back, but not as badly.
Raising the force MPG sensor by 5 or 10 points might be a remedy, but I will need to do more testing to make sure and to fine tune the setting.
Old 01-29-2015, 01:52 AM   #6 (permalink)
Liberty Lover
j12piprius's Avatar
pwr off retries
I think increasing Pwr off Retries simply delays DFCO, instead of getting rid of it, so the choice is a tradeoff. I like to use DFCO more in heavy traffic on the freeway, going up hills, steep downhills, and anywhere that shifting to neutral is not convenient. However, I'm raising the pwr off retries to 25 to give the kill switch another try, which will cost about 7 seconds of DFCO, and hopefully won't make much difference to the average mpg reading.
Changing the force MPG sensor ended up messing with the mpg readout, so I put it back on the original setting.
Old 01-29-2015, 07:01 AM   #7 (permalink)
Team Turbocharged!
Pickups
In my experience, PWR Off Retries has no effect on DFCO detection.
