Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-06-2014, 05:00 PM   #11 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
I have a brother in law who's a mechanic and he had to go to a continued education class were they stated that your only getting about 40% gasoline at the pump and the rest are the additives that supposedly "clean" the engine. From what I've seen Coleman cooking fuel is supposedly 100% gasoline but it boils at 180, if I remember correctly, and also burns too hot for a gas engine. I've always wondered if you could take a engine and have the fuel heated to a gas at a specific pressure then feed it into a engine with no throttle body so it's like how a diesel is and see if it would run.
Also if fuel combusts at 14.5-1 air fuel at atmosphere, then could you power a engine at around 14.5-1 if it has a 10-1 compression ratio??
I've looked everywhere for a graph that shows how hot gas is at a controlled oxygen supply but haven't been able to find one!
