Old 03-19-2014, 04:18 PM   #1 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Underhood Temperature
Thinking grille block.
What is the acceptable limit for underhood temperature? The engine coolant doesn't worry me - I run pure glycol. The intercooler isn't that important. If the A/c quits, I'll know it. But melting stuff under the hood is bad news.
Big trucks have engine compartment vent openings on the side.
Any ideas about temperature limits?
Anybody put a gauge under the hood?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 03-19-2014, 05:17 PM   #2 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
I don't have a specific answer for your truck, but most most OBDII cars have intake air temperature sensors. I can read it on my ScanGauge. I've blocked off the outside vents to my air intake, sort of a warm air intake. I've seen temps as high as 140 degrees on the hottest days. If anything it helps my fuel economy, especially lean burn and warm up times. My advice would be to have a way to monitor the temperature. Intake air temp is one way to do it if you have a scangauge or ultragauge (although it may not be as accurate if your intake sources air from outside the engine bay). A cheap remote thermometer is another option. You could monitor the temps for a few days under a few different conditions to make sure it stays within acceptable limits. As far as those limits go, you are probably safe up to 150 degrees, maybe more. Most critical heat sensitive components are protected with insulation, and temps shouldn't effect them unless they come in direct contact with something hot.
1998 Honda Civic HX - My Project Thread
Old 03-19-2014, 05:28 PM   #3 (permalink)
90 day: 55.9 mpg (US)
Before I had my UltraGauge I had a cheap digital in/out thermometer on the dash, with the out temp feeler in the air intake. It even works when the key is off.
I could see it rise when waiting at the lights with the engine off, as the heat of the engine heats up the then stagnant air in the intake.
Old 03-19-2014, 06:02 PM   #4 (permalink)
Cool
Ive blocked grills of a few cars and rental cars with no problems. Now if you are talking about your truck you may want to leave some room for air if you are hauling/towing anything. If its just you and you are eco driving them Id block the whole thing off if you can watch your temps.
Its my experience truck drivers/owners are more concerned about the exhaust temp than anything else.
Old 03-20-2014, 12:10 AM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Ive seen over 200f in the intake, part of that was egr though.
Old 03-20-2014, 12:37 AM   #6 (permalink)
Chief Cook & Bottlewasher
Xterra - '13 Nissan Xterra Pro-4X
90 day: 18.63 mpg (US)
Wow! I've got a warm-air setup kludged in my Forester and monitor the intake air temp. I've seen it go as high as about 126 to 130 deg and I start to worry at that temp. Yall think that 130 to 140 would be OK? I remove the WAI and go back to stock in the summer.
Old 03-20-2014, 08:43 AM   #7 (permalink)
My sensor is a map/iat sensor in one, so it is measuring egr as well. I have no issues with those temps except on moderate to high load. I posted in another thread about mixing e85 to offset the extra high temps.
On the subject of the OP, as long as your heatshields are in place I wouldn't be too concerned. That stuff is designed to handle heat.
Old 12-10-2017, 03:23 AM   #8 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Before I wraped my exhaust manifold and turbocharger I was mesuring component(not air) temperatures @250-300°f after 1 hr @65mph, can't tuch anything ,with an IR temp gun...
after 100-150°f at the top of a grade after pulling900°f EGT for 10min and 650-800° f for the previous 30min with a grill block on my 1st Gen Cummins during summer. Pop the hood and grab a hand full of turbo snell and hold on to it warm but not bad . More power 1/2 as much lag, doing more with less (more efficient) . (You have a waste gate to solve lag but this would help) the components under the hood are designed with the specific heat zone of its intended use. I would say 350°, plastic starts to soften. So this would be my upper limit. IAT is no good for me and you, for reading the under hood temps . Our turbocharger heats the air when it compresses it. Then cools it with the IC we blocked .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-10-2017, 04:25 PM   #9 (permalink)
90 day: 19.36 mpg (US)
Had a pair of Jeeps that ran extra hot. Literally couldn’t open hood without gloves. Items mounted on firewall (hard plastic) showing 250F on temp gun
I shimmed up hood hinge and modified weatherseal on the side of hood that didn’t receive airflow for HVAC. That helped. A little too efficient in winter so removed shim. W-S mid was adequate year round.
The constant heat in Texas will eventually toast all plastic under hood. Cracks off or crumbles. Be reasonable about this. It becomes a never-ending chase of hard to find parts.
The Following User Says Thank You to slowmover For This Useful Post:
gumby79 (12-10-2017)
