Old 10-04-2011, 10:09 AM   #1 (permalink)
EcoFighter
TYPE-R KING's Avatar
TYPE-R - '98 Acura Integra Type-R
90 day: 31.04 mpg (US)
Smile CF hood Aero?
Just wondering what y'all think about my 6lb hood...is it more aero or less aero than stock. Its vented behind radiator. I have a pic in my profile album.
Old 10-06-2011, 01:35 PM   #2 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
Id take a guess to say its less aerodynamic without a complimenting belly pan. If you had a belly pan then the air might make some slight under hood pressure that needs to escape. Then I could see that hood being of some benefit. The smoothest hood for my style Mustang is the 01 V6 style hood. It had a single non-functional cowl in the center of the hood.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 10-06-2011, 06:29 PM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
The smoother, the better. More bumps and ridges mean more drag. The weight reduction will make a tiny tiny improvement but it will probably be cancelled out by the drag increase at higher speeds.
Do a belly pan and see how that treats you
Old 10-07-2011, 08:51 AM   #4 (permalink)
EcoFighter
Should I try a partial grill block also with belly pan? Since I have a vented hood...hood info..when it rains going down the interstate water doesnt hit the center of windshield.
Old 10-07-2011, 09:37 AM   #5 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Make good tunnel from front bumber to hood and I would say its better aero after that. Air should have straight and clean route out of engine bay. Place of that exit is at proper place in your hood. Grill block would be also a smart choice because looks like that hole is not as big as your bumber hole.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 10-07-2011, 10:24 AM   #6 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
aerodynamic drag from the front of the car is such a small percentage of the total that I wouldn't worry about it.
Old 10-07-2011, 10:39 AM   #7 (permalink)
EcoFighter
Well im not sure what to do next to my car...everything has to be removeable bc I don't want to decrease its value....Ryland I have a 81 commuta van in the works
Old 10-07-2011, 02:46 PM   #8 (permalink)
Sven7's Avatar
This should give you some ideas.
For what it's worth my belly pans are zip tied on for easy installation and removal.
Old 10-08-2011, 04:16 PM   #9 (permalink)
center outlet
If you blow a radiator hose at speed will you be blinded as glycol hits the windshield and is only smeared by the wipers?
