Old 11-24-2013, 11:20 PM   #1 (permalink)
Plain - '91 Honda CRX HF
90 day: 33.14 mpg (US)
update: my poor mpg crx hf
This is just an update on my intro thread here: http://ecomodder.com/forum/showthrea...tml#post399117 I figured the follow-up is more appropriate here since it's getting deeper than just "hello, this is what I drive."
My last tank gave me only 30mpg. I've now adjusted the valves, inflated the tires a bit for cold weather, and cleared some stale codes left in the ECU after I fiddled with the eacv and TPS.
I doubt my mpg was affected that much by the valves, especially since they were all in various degrees of within spec. I set them all in the middle of the spec range, so the next bigger feeler gauge wouldn't slide in.
I also doubt the stale ecu codes had anything to do with it. I never had a CEL, and yes, the CEL lamp works.
However, after doing valves, I decided to double check timing. It was about 25 btdc! Odd because, I had it nailed down at 16 in the summer. I'm surprised I never had ping! Anyway I set it back to 17 btdc. I figure 1 degree advanced over spec is probably good, since I got away with 9 for I don't know how long. I'm willing to believe my timing had something to do with my poor mpg. On standard pump gas, I bet 25 degrees is enough to start seeing some power loss.
I also think my driving habits might be playing a huge role. That last tank was zero highway, and my daily commute is 9 minutes with traffic. Basically, the car never warms up, so even with my problems fixed, it never runs in closed loop. Perhaps it's time to move farther away, commute by bike, or look at an engine heater. We'll see if the next tank shows any results from the most recent tweaks.
Incidentally, when I was doing valves, I pulled the plugs and noticed #1 looked a little rich. 2, 3, and 4 were all nice. I'm running some Techron to see if I can even out the fuel distribution. I know that's a terrible solution, but I had a half bottle so I just threw it in. I've also just today noticed the return of bouncing idle. Time to investigate vacuum leaks and coolant bubbles again. Ugh. It never ends.
Old 11-25-2013, 07:28 AM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Get a bike lol. How far is the commute? If its too far for a bike, get a scooter or moped and some heavy cover-alls to keep you warm.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
Ryland (11-25-2013)
Old 11-25-2013, 08:20 AM   #3 (permalink)
Replace the thermostat. It should warm up faster than a 9 minute commute. Is your temp gauge not showing a warm up (staying at the bottom of the range). Without coolant temp in specs the cold fuel enrichment will not stop. I can get my Fiesta above 40 MPG in the first 1.5 miles (about 2 minutes) of my typical drive (don't commute).
OE type Japanese thermostats usually fail wide open, so the symptoms are the same as no thermostat.
regards
Mech
Old 11-25-2013, 10:19 AM   #4 (permalink)
Yeah I just replaced the thermostat. Temp gauge used to be pegged at cold all the time. It warms up now but it takes just a little longer than I usually drive.
Old 11-25-2013, 03:31 PM   #5 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Winter grill block time
Shove a couple lengths of pipe insulation in the lower grill and be done with it. I drive a Civic hybrid on a low speed (but 10 mile) commute. With the heat off, cold day, and no grill block, I'll be 6 miles in before ECT hits the thermostat opening temp. With the grill block, it's about 4 miles and then I can turn on the heat.
Old 11-25-2013, 05:47 PM   #6 (permalink)
That's kind of my number one option right now. But snow could present some occasional problems. Maybe I'll do that, plus a winter grill block for snowy days.
Old 11-25-2013, 06:01 PM   #7 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
More than you ever wanted to know about the Honda IACV - Gas Savers - Fuel Efficiency Forum
Also try re-learning the idle
more info:
Hunting idle when headlights on - Honda-Tech
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
FiShNc (11-25-2013)
Old 11-25-2013, 06:46 PM   #8 (permalink)
Xntrx, that's a great explanation of Honda idle systems. Not surprising i guess considering the source. I'd say it's a must read for anyone with idle problems. Thanks for that.
Old 11-25-2013, 06:50 PM   #9 (permalink)
zero highwy
I'm driving my 1st-gen HF again and if I do just the 7-miles from home to here where I use the computer I'm seeing no better than 34-mpg (tank mileage).
If I top off and hit the highway at the old 55-mph speed,she'll pull 52-mpg 'naked'.
The stop and go and short commuting never allows the the car to reach equilibrium warmup conditions.
Old 11-27-2013, 02:55 PM   #10 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
block heater!!
Burn lean and prosper \\ //
