Old 02-03-2015, 09:38 AM   #1 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Question upper or lower grill block for volvo s40
Hi for front grill blocking or lower valance vents which would be best for aero. Volvo have made a front valance block to fit my volvo s40. Would i be better to follow volvo or just go with grill block. My volvo is fitted with a trip computer which measures temp in 1c increments so i could measure temp variantions quite accuratly. Any comments or advice will be gratfully received.
thanks
dave
Old 02-03-2015, 10:31 AM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
any links or pics of the Volvo options?
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 02-03-2015, 12:26 PM   #3 (permalink)
s40/v40 front end
Hi hope this link works http://i783.photobucket.com/albums/y...psckkhdxdq.jpg
Old 02-03-2015, 12:28 PM   #4 (permalink)
Bottom vent is just under number plate. Yes its a 2001 model but mine has same front body panels.
thanks
dave
Old 02-04-2015, 12:17 AM   #5 (permalink)
Spaced out...
Interesting. Usually this site recommends blocking the upper grill. The reason for this is engine compartment turbulence. Air coming across the bottom of the radiator doesn't have to go as far, or jump through as many hoops, to exit the engine compartment as does air that comes in through the upper grill. Not sure the difference would be noticeable between the 2 options, but a factory grill block is probably going to fit nicer, look better and require less work than a DIY.
-Mike
Old 02-04-2015, 03:36 PM   #6 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I would block as much as possible without overheating. Start with the top and go from there.
The Following User Says Thank You to whatmaycome14 For This Useful Post:
Daox (02-04-2015)
