Old 10-06-2010, 02:14 PM   #41 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by winkosmosis View Post
This makes no sense. Let's say you have a grill that's 2 square feet. So you put a turbine in, and because of the restriction and energy sapped away by the wind generator, it's now effectively 1 square foot.
You'd be better off making a fairing to restrict the hole to 1 square foot aerodynamically.
You can't get something for nothing.
Thanks winkosmosis,
That's exactly what I tried to elaborate in the second post of this thread.
Jim.
Old 10-06-2010, 02:17 PM   #42 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
"requiring Cub drivers in Europe to figure out how to power the thing"
leads me to believe there's no alternator/battery system they can tap power off of - unlike a car. I'm not saying you can't generate electricity doing this, i'm saying it's a net loss.
Old 10-06-2010, 02:21 PM   #43 (permalink)
Old timer general aviation commonly used wind powered generators.
Old 10-06-2010, 02:39 PM   #44 (permalink)
never said it didn't
Old 10-06-2010, 02:46 PM   #45 (permalink)
never said you said it didn't
Old 10-06-2010, 03:13 PM   #46 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Sure.
And many aircraft have a small, normaly retracted emergency air turbine to generate electrical power just in case all engines quit.
But always at the cost of increased drag.
Old 10-06-2010, 03:19 PM   #47 (permalink)
...beats walking...
...uh, how often are you driving 75-110 mph in city traffic?
Old 10-06-2010, 03:24 PM   #48 (permalink)
I see what you did there....
Old 10-06-2010, 06:39 PM   #49 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Frank -
Do you think if this was front-dead-center, like where the license plate is, it would even spin, let alone generate more than one amp at 45-55 MPH? :
"Open circuit," Mattias writes, "I get 15.6-16.3 volts at 75 - 110 mph [indicated airspeed], and the short circuit current is 3.6-4.9 at the same speeds. As I have a quite robust battery (high current, long-life 28 amp/hour sealed lead-acid) I didn't bother to build a regulator. I just put two diodes (MR754) in series and hooked it on the battery. I judge the risk for over-charging as quite small.
"I've been flying with it for about 30 hrs now and I'm very satisfied. The biggest problem was to find a robust starter to convert. The ones sold nowadays are very cheaply built with a lot of plastic parts and simple bearings. I found a used "Pylon Brand Hi-Tork" with a robust metal housing and real ball bearings at both ends. It's a bit heavier (1.15 kg, 2 lbs something...) but that isn't really a problem for a Cub."
CarloSW2
American Solar Energy Society
Old 10-07-2010, 11:00 AM   #50 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
CarloSW2
At 55mph a square foot of well designed propeller (not counting the hub), could in theory, at best produce 200 watts, that would be enough to maintain the electrical system on a gas car, but the average speed of a gas car is not 55mph for most people it's closer to 35mph, unless they pull out of their driveway right on to a freeway.
But that 55mph wind speed would need to be straight line air flow, no obstructions in front or behind it, at all.
The Following User Says Thank You to Ryland For This Useful Post:
talldudenumber5 (10-09-2010)
Carb: cold air vs hot air aussie_modder EcoModding Central 16 10-06-2009 08:05 PM
cooler air via the vent? GoodOak Aerodynamics 7 08-22-2009 05:08 PM
Air Flow - Up and Over or Over and Under jrod 5.0 Aerodynamics 4 08-07-2009 06:29 PM
cool air for inflating tires NiHaoMike EcoModding Central 11 06-23-2009 10:00 PM
106-mpg Air Car for Only $18,000 Coming in 2010 SVOboy EcoModder Blog Discussion 24 01-03-2009 06:34 PM
