Old 09-20-2010, 01:27 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
what would happen if you were to use your egr valve to supply
fresh air to the engine instead of exhaust? Just curious.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-20-2010, 02:06 PM   #2 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
The engine would run lean and try increasing timing when it sees that the EGR is open then sense knock and reduce timing and/or close the EGR. It would be like having a vacuum leak in the engine and it would not be able to measure the total air coming in accurately, also the O2 sensor should see the extra air and add fuel to compensate.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 10:43 AM
How to: reduce the rich condition of a cold start. C3H8 EcoModding Central 69 09-10-2010 03:53 PM
Coates Spherical Rotary Valve Engine cfg83 EcoModding Central 5 08-14-2010 12:16 PM
Hey Civic VX owners - I need your help - please test your egr valve jadziasman Off-Topic Tech 5 06-27-2010 07:56 AM
