Old 10-02-2009, 05:03 PM   #11 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Thanks aerohead, although I think the xfi convertible has a lot of nice touches in it. In fact, he's only a few miles from where I grew up!
As for putting the pipes under tension, its made of thin wall EMT. at 1$ for 10 foot its hard to go wrong, but it is extremely 'wobbly'. By pulling them into each other a bit and tieing them together, it takes a lot of the 'wobble' out. If you look at the pictures, you can tell the 5 pieces that actually touch the car are all bending a bit, which is where the tension (clamping) is coming from.
It wasnt a bad attachment method, although I dont know if I'd do it again. I learned too late that it was scratching the car some, hence the masking tape wrapped on in some of the pictures.
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Trailer Hitch Boat Tail? superchow EcoModding Central 16 04-26-2010 02:35 PM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
Any Tips on hypermiling Subaru Outback? dremd EcoModding Central 3 11-15-2008 03:44 PM
