Old 03-26-2013, 06:25 AM   #111 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Sorry I didn't get your message from last year, I have not visited for a while.
I removed the valence block, and kept the other blocks, this does not overheat. I had some warmer temps with the valence block with a small intake. It just was not worth it to me.
I have a 5 speed 1.6 l Base version. 11% is a big jump for gearing but it is so undergeared at the moment, I think it would take 5% to get it to a normal condition, and I want overdrive.
Nissan Versa Aeromods
Old 03-29-2013, 09:29 PM   #112 (permalink)
skyl4rk's Avatar
Well I ended up with some Uniroyal Tigerpaws. 185/75/14. First day, I hated them, felt like driving through mud. But then I added some air pressure and ran them at 50psi and adjusted the Scangauge using a gps speedometer. Now I like what I see on the scangauge but I need a coupla fillups to properly calibrate before passing judgement.
There is no way the bigger tires at 205/75/14 would have fit on my car, the wheel wells are just not big enough. The 185/75/14 s are pretty much filling the wheel wells. I have adjusted the speed calibration on my Scangauge +9%. I don't know if I ever properly set it for my old wheels so can't say how the current circumference compares to the old one.
I like the tires now. We still could get a blizzard or three this season and I feel like I have some tread to plow me through the mud when necessary. 50 psi and I am a fan of Tigerpaws.
Old 03-30-2013, 05:05 PM   #113 (permalink)
skyl4rk's Avatar
I went from 185/65/14 to 185/75/14, which is a 6% increase in circumference, according to the tire size calculator. I am pretty happy with how this drives, the rpms are lower at cruising speeds. I had to start from a stop on an incline, and did not have a problem with the 1st gear being too high, it was just about right to get moving.
These were the numbers with the original 185/65/14 tires.
40 mph -> 2000 rpm
50 mph -> 2500 rpm
60 mph -> 3000 rpm
70 mph -> 3500 rpm
Note that I do not recall if I calibrated the Scangauge speed using gps, so the speed may not be 100% accurate. It should be close but ...
I will get new numbers with the new tires.
Old 03-30-2013, 09:25 PM   #114 (permalink)
skyl4rk's Avatar
40 mph -> 2000 rpm
50 mph -> 2500 rpm
60 mph -> 3000 rpm
70 mph -> 3500 rpm
Compare to the 185/75/14 new tires:
40 mph -> 1837 rpm
50 mph -> 2325 rpm
60 mph -> 2762 rpm
70 mph -> 3250 rpm
In each case, between 7% and 9% difference in rpm.
The original speed data were taken looking at the speedometer, the new data from the Scangauge mph readout, after having calibrated the speed +9% using a gps speedometer.
Old 03-31-2013, 07:19 PM   #115 (permalink)
skyl4rk's Avatar
The Following User Says Thank You to skyl4rk For This Useful Post:
brucepick (03-31-2013)
Old 04-01-2013, 04:02 PM   #116 (permalink)
90 day: 51.82 mpg (US)
I trust you have wheel covers.
Looking forward to results of this experiment.
Review: 2008 Nissan Altima 2.5 S, CVT RH77 General Efficiency Discussion 10 03-09-2010 02:40 AM
LA Auto Show: Nissan, 370Z, Cube, etc SVOboy EcoModding Central 1 11-20-2008 01:41 AM
Nissan mods the Versa: fuel economy up by 1 MPG MetroMPG EcoModding Central 28 11-18-2008 07:38 PM
Nissan raises the bar: networked, onboard, "multiplayer" fuel economy instrumentation MetroMPG Instrumentation 12 02-07-2008 04:01 PM
Dan Neil for president! (LA Times Nissan Cube review) MetroMPG General Efficiency Discussion 2 01-30-2008 01:03 PM
