Old 01-12-2011, 03:40 PM   #11 (permalink)
phh
Wifie's car - '89 Eagle Summit DL
Originally Posted by star_deceiver View Post
I try to keep the highest vacuum possible at speed. This becomes difficult with hills/mountains, sharp corners, ect.
Going up hills... define hills, here we have 8-10% grades... keep your speed constant. I find dropping a gear to hold your speed nets the same results as bogging down in a higher gear with your foot to the floor and slowing down necessitating a downshift anyways and using more throttle to regain the speed of traffic!
I see add-on gauges and instruments in your picture. What are they and what are their functions?
Old 01-12-2011, 04:57 PM   #12 (permalink)
...beats walking...
...the little round meter, just above the air-vent, is an Auto Meter 9100 ecometer™.
...I also have a 2009 Vibe and, for awhile, also used an Auto Meter before I moved up to the ScanGuageII
Old 01-17-2011, 01:54 AM   #13 (permalink)
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
And behind the Ecometer Ecometer from Auto Meter is my Sirius Satelite radio.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
Old 02-01-2011, 04:44 AM   #14 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
Originally Posted by nemo View Post
Never having used a vacuum gauge for anything other than diagnostics. I would like to hear from someone that is using one and what process they are using.
Highest vacuum in the highest gear possible? Keep a constant vacuum up hill? Are you only concerned with drops in pressure? What about shift points in an automatic?
I use a vacuum gauge tapped into the distributor vacuum advance line.
It reads zero vacuum at idle, slowly rising with gentle throttle opening up to 95kph or so, then falls again as the throttle is opened further.
I'm not sure that this is a better indication of economical driving than the "normal" connection but it works well for me. I drive to maintain the highest reading in top gear that the terrain allows.
Of coures this only works on older models that have vacuum advance.
Old 02-01-2011, 10:01 AM   #15 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
my Jeep Liberty is the same way, i leave the overdrive off until i'm up to about 50 then turn it on, if i don't do that the TC locks around 40-45 and bogs down the engine. my Big Beige Brick gets it's best mileage between 65 and 70
How to use the road load equation [wiki talk page] RobertSmalls EcoModding Central 21 11-19-2010 07:43 PM
