Old 12-20-2010, 07:06 PM   #1 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
variable exhaust?
What kind of results can I expect from putting a variable exhaust on my vehicle?
Old 12-20-2010, 11:23 PM   #2 (permalink)
...beats walking...
...variable what?
• pipe = length, diameter, temperature?
• valve = lift, diameter, timing?
Old 12-21-2010, 01:51 AM   #3 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
hes talking about variable exhaust valve that sits in the exhaust pipe
(most are butterfly valves like your throttle body butterfly valve)
it closes the butterfly vavle at low cruizing loads to improve low end response (as you now have more back pressure so gasses escape easier compared to a bigger exhaust)
then it opens as load increases (like w.o.t)
all this is controlled either by your ecu or by engine vacuum
as for an increase in fuel economy well i wouldnt know but if you ask me you could invest your money in something abit more worthwhile, like a "economy grind camshaft" or a some intake mods and stripping emissions devices to increase fuel economy.
do a google search and some reading on it and report back as you have me interested on if this might do something or not (if it does then i'm moving upto a bigger exhaust hahahaha
Old 12-21-2010, 04:09 AM   #4 (permalink)
Well that's what I have now, but I am going to redo the whole thing with one high flow muffler and 2" piping ( good for 150ish hp flow wise) and butterfly valve that's going to open at 5k rpm controlled by ecu, and the other one with a stock muffler and 1" piping that should be good for up to 40ish hp ( perfect for light throttle cruising). Basically the exhaust is going to have to go through stocking muffler and 1" pipe 0-5k rpm ( velocity should be at it's max around 4.5k) and after that 5k-13k the exhaust is going to be routed to go through both pipes and both mufflers all together should be able to support 200hp or so which is about what I need. I could have done 3 stage set up when it starts with 1" pipe, then goes through 2" pipe and then both pipes, but I'll see how this works out and if it does good 10% or so I might step up to a 3 stage set up and go little further in the head, plus intake variable length that is little more complicated, but is doable. The name of this game is velocity, try to keep it as high as possible without backpressure, because we all know, backpressure is not good.
Old 12-21-2010, 04:31 AM   #5 (permalink)
sorry ment higher velocity
Old 12-21-2010, 09:33 AM   #6 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
So you are going to have more then one exhaust pipe?
Smaller exhaust pipe is not used for more back pressure, it's used for greater scavenging, back pressure is caused by blockage, you don't want blockage, you want your exhaust to use the pulses to your advantage because exhaust is not exiting as a steady flow.
Old 12-21-2010, 01:25 PM   #7 (permalink)
I cringe whenever I hear talk about exhaust backpressure.
Old 12-21-2010, 04:02 PM   #8 (permalink)
...beats walking...
...there are TWO determinants happening in exhaust "tuning":
• SONIC (acoustive) velocity (1100 to 1700 fps) which is temperature dependent.
• MASS (gas slug) velocity (up to 300 fps) which is pipe cross-sectional area dependent.
...one is 'why' headers are sometimes wrapped to hold-in heat, and the other is 'why' headers use different diameters and lengths.
Old 12-21-2010, 06:48 PM   #9 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Sonic Velocity is why headers are wrapped and Mass Velocity is why tubing is sized, right?
From my weak knowledge, the diameter of the tubing determines the torque range based on the engine configuration.
I can't help with the variable exhaust but I do know of a variable intake design.
Ford uses a second set of throttle bodies in their engines to improve the low end air velocity for better low end torque. I've personally seen them in the 3.8 liter V6 in the Ford Windstar where they were located one in each intake just before the fuel injectors. But I know they also used them in the Ford Ranger at some point. The switch to full open was in the 2k-3k RPM range.
Sorry that I can't be of any help.
-Allch Chcar
Old 12-21-2010, 09:20 PM   #10 (permalink)
Ditto,
If this really worked, every car would already have it.
